I'm wondering if anyone has gotten to know the 95+ system well enough to answer this question? Forget about the 93/94 for the moment - lets focus on the 95+ because I notice on these models there is a California-only model with an EGR temp sensor. We'll tackle that next, OK?
I'm wanting people to THINK before they reply on this - I'm specifically asking 'how does the EGR system sense that it's not getting enough flow?' I'm not asking how does the system work as I've read through it enough times I understand it, and am going to explain that in case I'm wrong:
At low temps, the EGR valve is kept closed by the EGR's VSV (vacuum sensing valve). When engine temp raises, the VSV simply clicks open and sends vacuum to the EGR valve which opens and admits exhaust gases into the combustion system.
If I'm wrong, please advise but that's simplistically how it works.
So, if the VSV works, but the system is still not "getting enough EGR airflow" then what I'm SPECIFICALLY asking is what is the system using to detect airflow? Clearly there's not an air-mass flow sensor there (like the intake side has for example). Clearly there's not an EGR valve position sensor there (like the intake throttle position sensor for example). So what is it that's telling the EGR system it is not getting enough flow?
I'm guessing it's a temperature sensor that at full airflow should be sensing hot exhaust and when it's just a fraction below its expected temperature the system assumes it is not getting full hot exhaust airflow enough to heat the sensor fully? Am I right? I can think of no other way the system can detect lower airflow.
So, please no longwinded posts on the entire system - just tell me how 'low EGR airflow' is detected by the system. Thanks!!!
DougM
DougM
