Pulled my F engine to replace gaskets and seals (I figured they were original from Jan '73). Imagine my surprise when I found one of the larger diameter timing cover bolts was mongrel (not std Toyota with indented head and captured washer) and one of the small bolts spinning but not unthreading. I had to cut the spinning bolt off with a wafer wheel, and look at the nozzle:
Is there any way this is stock? A piece of all-thread with a slot on the end? Held in place with a glob of old school Permatex No 1?
It does have a squirter hole, and this shows the cut-off bolt shaft:
So, comments are requested on the following plan:
Pull the camshaft (I would unbolt the rocker arm shafts and remove the push rods and lifters) to get the front plate off, and replace the front plate or somehow fix the threads on the broken bolt.
Get a real oil nozzle.
In this deep, replace all the freeze plugs (I know, the Toyota versions, not generic.)
With the oil pan off, clean everything up,
Speedi-sleeve for the harmonic balancer (I can catch my finger nail (barely) on grooves cut by the front seal)
(the dizzy and fuel pump are already out; I planned to replace the valve cover gasket, push rod cover gasket, oil pan (leaking through the bottom) and oil pan gasket; the rear main oil seal; the welch plug on the end of the camshaft seems to be leaking; etc. etc.
Any comments?
Thanks!
Any comments?
Thanks!
