Having a problem...vibrations at 100kms.
Once again I have an auto. The tenant has been updated and has a new tc and 3rd and 4th gear lock up. Long story short, as short as possible.
This vibration at a 100 is when the gas pedal is on. In action. At the speed of 100 (giver take 5) I can be at the speed of 100 and release the gas pedal -result - vibrations stop. Smooth sailing. Once I'm at 120 the vibration is there but not as loud. I can cruise comfortably at 130. Strange right!?
Here's a check list:
-U joints - good
-rear Drive shaft - balanced and angles good
-front drive shaft is unknown
-Tires- balance
-Alignment - good
-engine mounts - good
-front end - good(rebuilt and to spec)
-rear diff: arb went in and wow that solved a lot of clunking. Spider gear was so loose.
-transfer case output flange is good
-rear pinion bearing is good
Was told to check my rear diff. But if something was wrong in the rear diff then would it not have a similar vibration the whole time?
Any insight would be greatly appreciated
-U joints - good
-Tires- balance
-Alignment - good
