I really doubt jet-tard has done the repair ever, he's been a long winded idiot on this site for years. I used a claw hammer to pull the seal, took 1/5th of a second. the bearings are sealed and can easily be checked for play, do not make this a giant job, it isn't. If the bearing has play get it replaced otherwise put it back together and get on with life.
OP. You need to seriously consider taking advice from this poster. He clearly doesn't have a f'n clue what the rear axle bearing design is or how it's engineered. He did a half assed repair on his own junk and is promoting doing the same. He wrote something stupid about how centrifugal force will allow the gear lube to bypass the bearing without going through it - which makes no sense if you see how it's designed. That's simply not possible. I've explained that multiple times. This is very simple.
Anyway, take a look at how the setup is designed. The wheel bearing is a sealed bearing. It's pressed tightly into the bearing retainer pocket and onto the axle shaft. There is only one route for gear lube to leak into the rear drum - by going through the bearing. Even if the bearing weren't worn out, it now has both the wrong lube in it, and seals on both sides have failed, meaning that the lube that is now in it is going to leak out. He genuinely doesn't have a clue as to what he's writing about, or he's trying to convince you to do a half-assed repair yourself. Why he'd do that? I have no idea.
The wheel bearing is the only thing holding the axle in place. If it has a catastrophic failure, the axle shaft along with the wheel and tire can fall out - as in come completely free from your vehicle. I've had the total meltdown situation by not replacing a bearing when it was due combined with big tires and serious abuse offroad. Mine didn't actually fall out, but it wasn't far away. Had it happened on the interstate - who knows. It sucks. Fix it right the first time. Don't do the backyard hack job on it and hope it lasts a few thousand more miles. You'll be back in there replacing it again shortly. You'll end up having to pay for new brake shoes again, and another tear down. Do it right the first time.
