Help - Oil Leek
Discussion in '40- & 55-Series Tech' started by Jonathan_Ferguson, Sep 5, 2003.
  1. Jonathan_Ferguson
    Jonathan_Ferguson ★ is in the wrong locale SILVER Star
    1,002
    60
    Jul 2, 2003
    Glen Waverley, Victoria, Australia
    [​IMG]
    The Oil appears to be coming from the front of the Transfercase(Looking from the left side).
    How do I fix it?
  2. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    well, i have the same exact leak.
    when i rebuild my case i made especially sure to get that housing sealed on there real nice with the gasket sealer and what-not.... but it still leaks.
    you can try to drain the case and get the housing off to put on a new gasket (complete rebuild gasket kit is cheap) and see if that helps.
    it's been a while since i did mine and i can't remember if you have to take the shift linkage off.
  3. godzilla
    godzilla
    254
    Apr 20, 2003
    If your oil is leaking from the front driveshaft on the transfer case you'll have to replace the oil seal. Check out specter off road, they have detailed diagrams of the transfer case. I've replaced these seals on my two fj40's, it's pretty simple.
