I just reread one of your earlier posts, where you checked the static timing. With #1 at TDC, the points should be open, not closed.
is the condensor hooked up?
The blue wire from the condenser must be connected to the white wire on the points. I'm surprised the engine runs at all without the condenser connected. Once you get things sorted out, be sure to grease the rotor, but only use a small amount. Usually a tune up kit gives you a small capsule of grease. If not, use something like Lubriplate grease. If you don't, the points rubbing block wears quickly and the points gap closes, and eventually you will not get the engine started.The wire coming out of the condenser is screwed down to the plate under the condenser, common with the plate that the points are mounted on. This can be seen in the image I posted earlier today. Is that the correct configuration?
