I have a Kaymar bumper and will have the ARB in 2 months, one day, not to far in the near future I will tow something, I'm sure what, but I will tow something, does/can the stock OEM Toyota flasher handle an ARB (w/turn signals) & Kaymar bumper along with a "normal" trailer - normal being something that you rent from Ryder/uhaul type of company.
Rick, I know you really did try everything. I guess I've got to consider myself lucky that replacing all the trailer lights with LED's worked for me.
Nak - any update/luck?
Does anyone have a link to a good wire size chart for 12v DC?
-B-
I've tried to read all the posts in this thread to try and figure out what's going on with mine. My symptom seems a little different.
I also have ARB front and Kaymar rear.
- hazards work all 4 corners
- activate turn signal ...flasher just buzz's, no turn (lights)indications
- fuse is still intact.
- went to dealer, bought a new flasher (relay), ...didn't fix, same symptom
- this happened about 2 weeks ago, I realized I had a bad bulb on front left of ARB. ....removed front right(other side) ....problem solved
- now the "buzz" is back, hazards work all 4 corners, no turn indications again
- disconnected both Kaymar turn signals, no change, flasher still just buzz's when turn signal is activated on the column.
can any of you offer any thoughts as to what might be going on here?
