Heat riser insulator on 2F
Discussion in '40- & 55-Series Tech' started by Webster, Apr 10, 2003.
  1. Webster
    Webster
    236
    Feb 20, 2002
    Does anyone know the value of the metal insulator placed between the 2 heatriser gaskets? I had an exhaust leak and mine is burned through. Wondering if I can install new gasket and leave the insulator out?
  2. JasonH
    JasonH
    2,130
    Media:
    1
    45
    Jul 12, 2002
    McKinney, Texas
    If you're talking about the flapper valve between the intake and exhaust, you do need it.
    When the engine is cold, it directs warm exhaust onto the bottom of the intake manifold. When the engine is warm it diverts the hot exhaust away from the intake. If the valve isn't there or is stuck open, the heat will crack the intake manifold.
    I replaced mine with a new one from Toyota. I don't think it was very expensive.
  3. Webster
    Webster
    236
    Feb 20, 2002
    Actually not the flapper valve, but there is a thin metal insulator sandwiched between the gaskets that sits between the flapper valve and intake manifold. I had the crack welded and reinstalled last night. So I have all new gaskets in the exhaust system and still have a mystery leak. I'm getting very nervous that I might have a blown head gasket!
  4. JasonH
    JasonH
    2,130
    Media:
    1
    45
    Jul 12, 2002
    McKinney, Texas
    OK. I had confused myself a little. I was thinking of that insulator when I said I replaced mine, but I was describing the valve itself. I think I have one if you need one still.
  5. Webster
    Webster
    236
    Feb 20, 2002
    You have the thin sheetmetal insulator? Yes I could use it as I am not to comfortable with the weld repair and I had also noticed new cracks starting that we didn't weld. How much?
    Thanks
  6. JasonH
    JasonH
    2,130
    Media:
    1
    45
    Jul 12, 2002
    McKinney, Texas
    Let me verify that I do have one. Let's say $5 plus shipping. If I can't find it, you should still be able to get one from Toyota.
