Headlight replacement bulbs ?????
Discussion in '80-Series Tech' started by Big_Moose, May 17, 2003.
  1. Big_Moose
    Big_Moose
    426
    Aug 26, 2002
    Couple of quick questions from lurk mode......
    1) What is the factory Hi & Low beam wattage?
    2) Quality aftermarket replacement bulbs? / wattage available?
    3) Can the lighting enclosure handle the temperature / heat increase?
    All my other cruisers run Hella's w/H4's, which gives a nice crisp 130watt Hi & 100watt low beams. I noticed that Hella only sells replacement 90005/6 bulbs in 100 / 80 watt configuration.
    I just purchased Christo's head light wiring harness, and was wondering if there are other replacement bulbs and / or large wattage?
    :beer: :beer:
    Joe
  2. Hltoppr
    Hltoppr SILVER Star
    2,021
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Joe, although I run stock bulbs and wiring, I believe that you should be able to upgrade the bulbs to the Hellas if you also upgrade the harness. I have not heard of any problems with the enclosures when bulbs are upgraded.
    -H-
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Stock is 55 low, 65 high
  4. DRTDuck
    DRTDuck
    624
    9
    Mar 28, 2003
    Boulder, CO
    I have seen the PIAA superwhite bulbs reccomended on other discussion threads. They have said they are worth the money in brightness.
    I put in a some generic "superwhites" from the auto store, about $15 a pair, a couple of years ago, they were better than stock, and with Christo's harness upgrade are even better and are still burning. I also run with the lights on always and it is my daily driver.
  5. Ron_Z.
    Ron_Z.
    25
    Jan 13, 2003
    I just upgraded mine to the wiring harness from Christo and also the IPF #9005 headlights. WOW 8) The wiring upgrade is a 1 :banana: job. The harness is about $40 but the lights about $105 (then again the PIAA's were $90) We went out to the Smokies and the new lights made a huge difference.
    HTH.
  6. CDN_Cruiser
    CDN_Cruiser
    1,047
    Mar 27, 2003
    Ditch, what is the output of the IPF lights? I would love to havr the light that I run in my motorcycle - 100W high and street-legal 55W low.
    Cheers, Hugh
