Headlight Plug
Discussion in '40- & 55-Series Tech' started by ScarboDP, Mar 6, 2003.
  1. ScarboDP
    ScarboDP
    51
    May 30, 2002
    Im rewiring my 1969 40 right now the plug that plugs into the back of the headlight has three wires one is ground, on the switch it also says "pass" and "drive". Which is the high beam and which is the low beam?????
    -Thanks
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    pass is high, drive is low....guessing, but sounds right.
    You could always hook up with some household wire twist locks and test real quick....I do that all the time when I'm not sure on a connection...or just a touch of electrical tape to protect the twisted wires.
  3. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    Sounds right, but in many countries drive is high and you dip your lights with oncoming traffic. You could wire em up with jumpers and see which is brighter.
    My JDM motorcycle had drive and dip symbols on it.
  4. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    Just wire them (left and Right) the same if it is not correct you should be able to reverse them at the switch, or slide them out of the connector by sliding something thin in next to the female connector to push the catch over to slide the wire out.
