I just got some new headlights from eBay and they use an H4/H1 bulb combo rather than the stock 9005/9006 combo. I figured since I had to do some rewiring that I would add some relays and clean up the wiring a bit. My question is this; the H4 uses three terminals, a high beam, a low beam, and a common. The 9005 and 9006 only have two terminals each. My cruiser has four colors of wiring in the stock harness; black/white, red/white, red/yellow, and red/blue. The red and blue are common to both bulbs on the passenger side and the red and white are common to both bulbs on the driver side. The red and yellow only go to the 9005 (high beams) and the black and white only go to the low beams. Which of these would I use for high, which for low, and which for common? This is on a '92 FJ80. I would post the stock wiring diagram but I don't want to get in trouble for copyright violation stuff. Can anyone help me? Thank you. I am using the attached schematic to wire up the new lights.
