Yes, Its the 1FZFE. The oil doesn't appear to be flowing in it. I also think that it is just really old coolant. The previous owner barely used the vehicle, but didn't do much as far as maintenance goes. I hope that it is just corrosion, and that I can flush it out.not sure which motor you have, but I will guess 1FZFE. Its hard to tell from your post, was that oil floating on top of the coolant, or is that the coolant itself? It could be just very old coolant that is discolored. Aparently oil cooler failure on the 1Fz-Fe is rare.
Mine looked like that, and from what I could tell, it was a crap ton of Bar's Leak.
Flush and refill, do a Blackstone, as suggested above.
I didn't do the coolant test because my HG blew in a fashion that was undeniable but I believe this test is done while the engine is running.It is not my DD. Although, I bought it with intent of introducing it into the rotation. It will get more use in the summer. I will drain the coolant and analyze it like you suggested and get the oil analyzed as well. There are no visible leaks on the engine. It actually looks incredibly good, which is what made me want to buy the truck in the first place. I think I will start preparing to do the head gasket as a precaution.
Well, the HG may have been done already. Look at the half moons on the front of the head. If you see black sealant there's a chance it has been done once already. Grey would have been original. With the 1FZ when you consider the length of that block and that lightweight aluminum head on top of it, there's going to be movement. Period. The reason I suggest an oil analysis (and Blackstone is not the only one) is that you can go online and get any of your questions answered, get a free sample kit, and then send it in for less money than you'll spend driving down to NAPA to buy one of these exhaust gases kits. For less money you'll get a real baseline on your engine on a whole range of variables. There are opinions and there is science. As "El Skeltor" said in Nacho Libre, "I believe in science."It is not my DD. Although, I bought it with intent of introducing it into the rotation. It will get more use in the summer. I will drain the coolant and analyze it like you suggested and get the oil analyzed as well. There are no visible leaks on the engine. It actually looks incredibly good, which is what made me want to buy the truck in the first place. I think I will start preparing to do the head gasket as a precaution.
OEM, of course. Call CDan or Beno. Make sure you've got the FSM first of all. ARP might not be necessary. There are specs in the FSM, and I'd go OEM head bolts if it were me. (It's not the color of the HG, but the flexible gasket material around the access covers to the cam bolts on the head.) Don't worry bout that for now. The learning curve is good.I will definitely get an oil analysis and coolant analysis. I'll check tomorrow what color the gasket is, but i'm 99% sure that its original. The previous owner has not done anything other than oil changes. Are aftermarket eBay head gasket kits not the way to go, should i ONLY look for OEM? I'll definitely get the ARP head studs.
