Head gasket???
I’m wondering if I’ve blown the head gasket on my 1997 40th anniversary. When I get on the gas, particularly going uphill, and the rpms get around 2000 it hesitates and shudders. Not consistently though. If I’m on a downhill or flat it runs fine. On the way home today the check engine light came on.
I’ve looked around for a vacuum leak and did find a sizable crack in the hose that goes from the air filter to the throttle body. So right now its duct taped. I plan on replacing that very soon. I don’t smell anything burning and my oil looks really clean. Transmision fluid looks good too. Temps are all OK and my rpm at idle is fine. I can replicate the hesitation/shudder if I put it in drive and keep my foot on the brake and slowly get on the gas. Again hesitation/shudder starts around 2000 rpm.
The one wild card is it started about about 10 miles after I filled up w/ gas. It’s not the brand I usually run and was 87 octane. I’m just not sure bad gas would cause this.
Any thoughts you guys may have would be appreciated.
thanks in advance…jim
