Thanks. I haven't seen a Toyota listed online, but wasn't searching for it as you mentioned. I'll check it outToyota makes a whole kit that has everything.
Search: Engine Overhaul Gasket Kit
Superb! Great thread. Thanks a bunch, exactly the info I needed, and then some. One like going your way
Toyota PN: 0411266036
$121.86 at amayama Toyota 0411266036 Part Details - Search for Genuine Parts - Amayama Trading Co.
btw since you are there get some of the following:
injector connectors shrouds Toyota PN: 9098011153 ($3.86 at amayama 9098011153 - Search Results - Search for Genuine Parts - Amayama Trading Co.) just in case you will break a tab while you attempt to disconnect the injectors connectors....
exhaust studs and nuts Toyota PN:9011610169, 9012610006, 9017910037, 9017910070 (cheap enough at amayama just in case... 9011610169, 9017910037, 9012610006, 9017910070 - Search Results - Search for Genuine Parts - Amayama Trading Co.
also... don't forget about the PHH (OEM Toyota PN: 9955630100) or something else ... your choice...
regards
The Cometic gasket is a good choice, but only if you are doing a rebuild and can machine and finish the deck surface to a very high standard, correct?
The OEM Toyota (which is an updated design) is very tough and will last another 200,000 plus miles, even with boost (right, @scottryana ?)
I have read far to many reviews/posts of failed aftermarket head gaskets-beware!
