HD Sway Bars with OME Suspensions
Discussion in '80-Series Tech' started by BigMac, Apr 1, 2003.
  1. BigMac
    BigMac SILVER Star
    216
    Mar 27, 2003
    Lompoc, CA
    Does anybody have experience with Man-A-Fre's "Heavy Duty" sway bars - especially in conjunction with OME 850/863 springs? Their website doesn't state the diameter or anti-roll rate increase over 80 series stock sway bars. They include them in a "Premium" OME suspension, along with longer steel brake lines (but no steering stab) for a little over a $ Grand.
    Thanks, BigMac
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Cap'n,
    Before you slap leather and buy those, look around some. Go to Christo's site, etc... I don't see the benefit of "HD" sway bars on an 80 unless you plan to autocross it.
    None of my buds have altered sway bars, altered evreything else maybe........ :beer:
    Junk, what do you think.....?
  3. BigMac
    BigMac SILVER Star
    216
    Mar 27, 2003
    Lompoc, CA
    Cruiserdan:
    Roger that - I can see the drawbacks of super stiff sway bars (or any swaybars) in a rock crawling situation where you need every bit of free travel you can get, but I'm trying to strike a compromise between freeway driveability and off road capability. The stock bars may well be plenty. I autocrossed a BMW 1600 about 30 years ago - maybe I have forgotten those old lessons about street cars and race cars having NOTHING in common!
  4. landtank
    landtank SILVER Star
    18,425
    601
    Mar 27, 2003
    Groveland MA
    Back when I went to OME I bought the package from Man-a-fre with the sway bars. First the front didn't work out that well because there was no place to mount the hardware for the cabling to the locker. Now that there is three years on the rear one it has rusted severely and is noisy as hell. I never did put on the front one and am now looking for a rear factory one to put back on. My initial thought was that the firmer bars would help with towing which I'm sure it does but as of right now I'm going to go back to factory.
    Rick
  5. Hltoppr
    Hltoppr SILVER Star
    2,022
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    If you haven't installed the OME kit yet, I'd hold off on the swaybars.  My experience with 850/864 springs was that sway was actually improved over stock.
    Additionally, I've never heard of anyone having problems with the length of the stock brake lines with that height of spring lift.
    -H-
  6. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    As long as you don't drop the sway bar mounts post-lift the truck will be stiffer than your stock ride now.
    I drove my truck around for about a month without the sway-drops and then another month with no swaybars.  Then I decided to get the drop kit from Slee.  The kit restores the ride to close-to-stock.
    If you do not drop the swaybars you run the risk of over stressing them and ripping them from the mounting points.
    If you run with no swaybars (I wouldn't reccomend this one) the truck will be quite tippy and unstable feeling.  The rear end came loose once when I had to avoid a major accident on the freeway.  It was not a very comforting feeing.
    If you install DIY or other drop brackets/blocks the truck will feel much like it does now.  Mine feels a bit more tippy, but that comes from the ~4" of added lift, not the sway bars.
    Hope my rambling helps...
    Hey Dan, that was 6 paragraphs of nothing. :D
  7. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Rogue,
    The Wulf will be jelous............ :bow:
  8. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    This is just seat of the pants. I ran the HD sway bar in the front for my last trip of about 20K miles. (stock mounts) It seemed to make a big difference on the highway. Much more stable. Off road it appeared to limit wheel travel and actually make it more tippy. MAF had the rear bar on backorder when I left so I was unable to install it. I have it on now but my cruiser is still in my garage apart so I won't have an evaluation for another couple of months. Now I have 850J/864's, N73L/N74L's and I made up the extension block/brackets - running 33's. These extended shocks etc. may be futile if I can't bend the bar. Maybe someone could actually make a "softer" bar for more flex off-road instead of just disconnects.
    Bill
  9. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Nope. :slap: - got my quick disconnects just about done. :D Once I get 'em on and test 'em out awhile, I'll let y'all know what I think of 'em. :banana:
  10. Wrench
    Wrench One Bashed Up 80
    4,496
    179
    Mar 27, 2003
    Junk, You made sway bar disconnects? If so how did you do it? Can you post a pic?
  11. BigMac
    BigMac SILVER Star
    216
    Mar 27, 2003
    Lompoc, CA
    Thanks for all the inputs, Gents. I'll do this in phases - install the OME suspension and Slee's swaybar mount extensions first, then drive it a while before thinking about heavier bars.
    I know the springs differ - I wonder if stock LX 450 sway bars are softer than a Cruiser's? Thanks again, BigMac
  12. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Cap'n
    I'll check my LX450 catalog vs My LC and see if the part numbers are the same.... I'll get back to you
    Regards...Dan :beer:
  13. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    BigMac,
    The LX450 and the Cruiser use the same part numbers on both sway bars, the springs are the only difference........
    Regards......Dan :beer:
  14. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    :stupid:
    Junk
    I have been batting the sway bar disconnects idea around for about a year and havent thought of anything I would like to fabricate yet.
    Share the wealth and post us some pics
    while you are at it shoot a pic of your rear bumper(crossmember) I seem to recall you said you trimmed it up a bit and would like to see it.
    Dave :beer:
  15. BigMac
    BigMac SILVER Star
    216
    Mar 27, 2003
    Lompoc, CA
    CruiserDan-
    Thanks for checking - that seals it in my mind. I will go with the OME suspension and Slee's dropped mounts for the stock sway bars and see how that feels for a while. Can't wait to take delivery next Tue and hit the road west the following Monday. Thanks again, BigMac
  16. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Will post pics once its done :flipoff2: :flipoff2:
    Sorry - but taking off to wheeeeeeeeeeeeeeeeeeeeel.[​IMG]
  17. Beast II
    Beast II
    734
    Dec 23, 2002
    I have the Old Man Emu 2.5', heavy springs and coils and bullbar/winch /batteries in the front. I'd stick with the stock sway bars. I have the HD front and rear sway bars and I've had nothing but problems with them. The bushings all blew out and the roll during cornering and can get pretty bad. When out on the trail, the side to side movement was throwing my passengers around quite a bit.
    I just put in the f/r awr joints in the panhards, awr joints in the upper rear control arms (to eliminate the driveline vibration), drop brackets in back and drop blocks in front - the articulation is incredible, but the body roll side to side seems to have gotten worse - a reliable source thinks its the sway bars as they are too stiff. I just ordered Toyota swar bars and hardware to put back on and we'll see how it goes.
    Anyone else have this experience ?
  18. Imagery
    Imagery
    343
    1
    Aug 26, 2003
    Beaumont, Texas
    Since it has been found that the OEM sway bars are probably the way to instead of the HD's, could they be improved on by changing the rubber bushings with some Polyeurothane bushings. It seems like they could be stiffened up at the connecting points and still maintain the flex offered by the factory sway bars... ???
  19. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    I just replaced all the busings on my sway bars with new ones - all the hardware too. Big difference. Most don't realize how hammered they get after the years. Rubber = good - just ask your momma. :flipoff2:
  20. alia176
    alia176
    9,654
    440
    Aug 21, 2003
    Tijeras, NM
    Do most of you guys keep your sway bars connected while wheeling?
