Hand throttle install instructions, adjustment help
Discussion in '80-Series Tech' started by corn man, Jul 20, 2012.
  1. corn man
    corn man
    178
    1
    Sep 13, 2009
    Lincoln, NE
    Installed it, but idling high as I didn't adjust it for 5mm of free play per Slee's instructions:
    http://sleeoffroad.com/installation/ht_install.pdf
    Anyone know if I need to turn clockwise or counter clockwise to lower the RPMs? It is hard to see under there!
    Thanks in advance...
  2. KimoSabe
    KimoSabe
    552
    4
    Apr 10, 2010
    LGB Kamifornia
    :)clockwise will give the slack-lower rpm ...run your car in idle while you are doing the adjustment...:)
  3. corn man
    corn man
    178
    1
    Sep 13, 2009
    Lincoln, NE
    Thanks for the help!
  4. Bisonthecruiser
    Bisonthecruiser
    206
    6
    Aug 2, 2006
    Santa Rosa, Californ
    I'm trying to install the damned thing but keep running into trouble.
    1: Retainer/ball pin (check)
    2: Area in between adjusting screw and inner cable? WTF? I cannot figure out if that black piece slips into the steel on the bracket. Can anyone confirm?
    :doh:
    Cheers,
    Adam
  5. BlackLS1
    BlackLS1
    623
    2
    Apr 21, 2012
    granada hills,CA
    the black piece has two tabs on it, that is to lock the adjustment in place when you are done, push the black piece towards the adjustment nut to lock it into place, and press on the 2 tabs to undo the plastic piece. there is plenty of movement in the cable. you dont need to make the adjustment tight.
  6. Bisonthecruiser
    Bisonthecruiser
    206
    6
    Aug 2, 2006
    Thank you! The non lock piece slides into the bracket grooves, yes?
  7. BlackLS1
    BlackLS1
    623
    2
    Apr 21, 2012
    granada hills,CA
    yes, the black rubber with the groove will only fit one way, so you have to keep turning it till you find the sweet spot and force it into place on the bracket. then put the end of the cable through the bracket hole and clip in the little white plastic, and then move on to the adjustment.
  8. Bisonthecruiser
    Bisonthecruiser
    206
    6
    Aug 2, 2006
    Awesome! Thanks BlackLS1. That got it working nice and happy!
  9. BlackLS1
    BlackLS1
    623
    2
    Apr 21, 2012
    granada hills,CA
    im glad i could help
