Hand crank start?
Discussion in '60-Series Wagons' started by Flight2k5, Oct 18, 2010.
  1. Flight2k5
    Flight2k5
    244
    15
    Sep 16, 2005
    Carson City
    I still am in the honeymoon phase of owning my fj60 and have lots if questions. I noticed in the front it looks like there is a slot in the bumber to slide a handcrank through it and hook it up to the crank. Is that for starting it or for just bringing the engine to tdc?
  2. Zack1978
    Zack1978 SILVER Star
    2,843
    Media:
    1
    46
    Oct 12, 2004
    IIRC.........On USA spec FJ-60's it can't be used, as the radiator is in the way.
    Zack
  3. JLH911
    JLH911
    2,399
    4
    Sep 2, 2007
    So. Cal
    It's for a PTO (Power Take Off) Winch. Do a search and see.
  4. Flight2k5
    Flight2k5
    244
    15
    Sep 16, 2005
    Carson City
    It's certainly not for a winch. The slot in the bumper is only maybe an inch across and when I look down it I see the engine crank, not the tranny or tcase
  5. ntsqd
    ntsqd technerd
    4,996
    66
    Apr 26, 2007
    Upper So. CA
    I don't know why Toyota put it there, but having driven old vehicles that had the hand-crank provision that is exactly what that slot in the valence panel looks like. For it to be a PTO opening the shaft size to fit would be too puny to be of much use and I would expect it to be a hole rather than a slot. The reason for the slot is to clear the cross-pin in the end of the hand-crank. I don't recall my 2F having the necessary lugs on the crank bolt, and it certainly didn't have the clearance hole in the radiator, but that doesn't mean that other markets couldn't have received those. If it is for a PTO winch, how did it reverse?
  6. IH8Wood
    IH8Wood
    950
    Dec 3, 2004
    Altadena CA
  7. lehiguy
    lehiguy
    3,792
    8
    Mar 18, 2008
    Lehi, Porter Rockwell's home town
    Mine had the lugs on the pulley retaining nut and it was made in Aug. 1985. It was absolutely for manual manipulation of the crank. There are also ports on either side of the front crossmember for PTO shafts. I can't imagine wanting to try and hand start it, but for valve adjustment/tune up procedures it would be convenient.
  8. FJ40Jim
    FJ40Jim The Cruiser Whisperer
    8,956
    679
    Sep 26, 2003
    Lancaster, Ohio, USA
    It's for the hand crank. But all USA FJ60 have AC prep, so have the bigger (deeper) radiator that just drops down in front of the hole in the valance.
    I've never started a 2F w/ the crank, but years ago we started our old F-powered FJ40s a few times w/ the crank, just for giggles. This is done by warming up the engine first (no way my skinny butt is gonna crank a cold engine to life), then using the timing adjust knob on the early dissy to fully retard timing, then energize ignition and crank the bar.
    edit: I just watched the youtube link above. Yep, that is how it's done.
  9. ILYOTA
    ILYOTA
    43
    Oct 4, 2009
    LO-LOC Offroad Elmwood,IL
    just as long as the engine doesn't backfire while cranking or you could seriously hurt yourself
  10. KonTiki
    KonTiki
    190
    11
    Mar 4, 2010
    Gulf Coast
    The cog on the crankshaft is usually designed in a way that kicks the hand crank out of the cog if it backfires or starts up and turns faster than youre cranking by hand. Even with that, Ive heard of alot of broken thumbs and sprained wrists when using them.
    I have a hand crank just like that on my 74 land rover:rolleyes:
  11. Flight2k5
    Flight2k5
    244
    15
    Sep 16, 2005
    Carson City
    So if the rad wasn't in the way one could hand crank it?
  12. Joe_E
    Joe_E
    3,547
    Media:
    39
    126
    May 31, 2008
    the NJ word..
    Yep, my old 40 had a crank bolt that would take a crank handle.
  13. Joe_E
    Joe_E
    3,547
    Media:
    39
    126
    May 31, 2008
    the NJ word..
    Yes, I recall the nut had a weird swirl shape.
  14. JLH911
    JLH911
    2,399
    4
    Sep 2, 2007
    So. Cal
    you learn something new everyday
  15. lovetoski
    lovetoski SILVER Star
    4,321
    77
    Jul 13, 2003
    I know a guy who did some reporting for NPR in africa, and they hand-cranked 60 series cruisers as the "normal" way of starting. Batteries tended to be in poor condition I guess...
  16. ozwallaby
    ozwallaby
    542
    140
    Jan 25, 2007
    Qld, Australia
    You do a search and see it's not.........
  17. ozwallaby
    ozwallaby
    542
    140
    Jan 25, 2007
    Qld, Australia
    You making this up..........
  18. KonTiki
    KonTiki
    190
    11
    Mar 4, 2010
    Gulf Coast
    What part of that sounds made up?
  19. Pighead
    Pighead Stop calling it an FJ SILVER Star
    7,413
    44
    Aug 31, 2004
    Walmart parking lot
    I have used the handcrank to start my Pig many times. Sometimes for fun or to win a bet, sometimes because I needed to. 55s have that same front valance hole.
    There is a certain technique, and grip (don't wrap your thumbs around the handle) and the handles will bend if you're not careful.
    It is handy for adjusting valves too.
  20. FJ40Jim
    8,956
    679
    Sep 26, 2003
    That's why mine hangs on the pegboard in the main workbay. :cool:
