PabloCruise
It does kind of suck that Toyota a) never gave the US a 5 spd, and b) designed a 5 spd that relies on a $3 plastic oiler cup to prevent failure, c) prices this technology ~$2000.
TJ - there are a number of 'overdrive' transmissions where the overdrive gear is an afterthought, and suffer reliability issues. Agreed that Toyota should have offered a 5 speed in the US, especially on the FJ62, which is so hampered by the energy-sucking automatic.
I would be very interested in seeing someone do some more legwork on the ZF/2F adapter. ZF 5spds are bulletproof and extremely common in these parts.
Question on oiler cup. I'm looking at the 5 speed repair manual #223-08. It doesn't show the oiler cup in the diagram. Is it called something else or is this a part that is added to the H55F after a rebuild?
Did you ever give this a shot? Engine needs rebuilding in my 60 now, so I think it's time to consider the tranny as well while I have it all pulled.I am the culprit who goaded Lumpy70 into his heretical post re: the failure rate of the vaunted H55f. I am also in possession of numerous H55f’s, every one of them broken beyond repair for a variety of reasons. Most of them have been countershaft failures, possibly induced by front bearing failures. I did have a low oil induced front input bearing failure too, precipitated by the notorious ‘Pumping Oil’ failure mode that tends to drain oil out of your H55F and overfill your split case.
If you run an H55f within the performance enveloped it was designed for circa 1980 then you you have a great transmission for 90 kmph speed limits, with 29” tires, and behind 90-120hp engines. But… 35 years later, we run them at 130 kmph, behind V8’s or jacked up turbo diesels, with 35-40” tires. Clearly, this is why I have so many dead H55f’s in my possession.
While we Canadians did get a few thousand factory installed H55f's behind B and H motors in the 80's , new replacement B series input shaft have become unobtanium from Toyota. While you can still buy brand new H55f units for your H/F series motors, you are totally out of luck if you don’t have a donor input shaft for your B engine. And Input shafts are often destroyed when counter shafts fail… so, they are getting kind of scarce.
Which leads me to some of that aforementioned leg work…. My recommended replacement is, as already mentioned, the ZF5 S-42, specifically the early 90's Ford truck units from behind a gas engine, it had the following gear ratios.
5.72 2.94 1.61 1.0 0.76 -5.24
10 spline, 1-1/16" input shaft.
11" clutch.
31 spline output shaft.
Integrated bell housing with All aluminum case.
Here’s my KickStarter Idea:
Build a custom Adapter plate to go between B engines and gasser-version ZF S5-42 transmissions which use a factory Toyota starter and tach sensor. Use the F engine clutch (10 spline, 1-1/16 shaft, 275mm clutch). Use Factory Ford Clutch master/slave.
As for transfer cases, you have your choice of the Ford NP203, NP205, or NP271. Aftermarket Atlas Tcase are also available, which would the winning option if that’s in your budget. Another custom adapter to the Land Rover transfer case is also an interesting idea but more custom adapters with shaft adapters… all gear, offset rear output, AWD case with a fantastic reputation.
There’s a bunch of R&D to confirm that it’s even possible considering flywheels, starter locations, tack sensors, input shaft lengths, and so on, and so on…. But, no one invested in my kickstarter, so there you have it. I continue to toy with this idea for my own project.
