So now the bad boy 2 or extreme are black with a gold billet wheel.
So now the bad boy 2 or extreme are black with a gold billet wheel. So Bernie when are you getting one?
Is it likely that the 233kw set up will be run on the dyno again with a different (correct?) ramp rate...... so differences can be directly compared with this proposed new set up and the 233 and not having to be a genius on a scientific calculator....
:whoops: ramp rate of the dyno not ramp rate of the fuel pump LOL either way both need to be re adjusted , next month
M.
I'm aware of that , I have been making sure that I dont go over 450'c post T
The water to air cooler should be here this week but the FT R/cover maybe next or the week after that
Cheers Marty
Thats always been the great debate hasn't it , as long as you know what temps you run normally there is no problem using one pre or post
When the W2air cooler is fitted the max temp I would ever see is 380'c normal driving 180 / 250'c
My probe is not in the usual spot some 100mm back from the flange , mines is less then 25mm and directly in the main flow stream , besides the air intake temps also give you info on thats going on eg; 110'c in and 40'c for a 30'c ambient temp and the most Ive seen was 125'c / 50'c on a 38'c day I'd say ive got it pretty close to where it needs to be
Marty
The tip of my probe is 50mm through the pipe like I said mid flow directly behind the turbo wheel , I have never had any issues using mine this way , tell whats the difference between reading pre and post , you will still get a correct reading no matter what as you put your boost into it temp rises for both pre and post probes all be it maybe 100'c more for pre
You still get a sense for what goes on just the same
M.
We should all be running 6 EGT gauges then, one right at the exhaust port on each cylinder. It's a not accurate without knowing what each cylinder is running!
