Greasing Birfields
Discussion in '40- & 55-Series Tech' started by CruisinGA, May 17, 2003.
  1. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Ok, I'm pretty sure my birfields are empty or low on grease, I know to use Moly grease, but I can't find the plug or fitting to pump grease in through? :dunno: A guy at the club made a presentation on things to do pre-ride, and this was one of the things he mentioned. I can't find the damn thing? Help please?
  2. Gus
    Gus SILVER Star
    1,126
    Media:
    8
    63
    Apr 13, 2003
    Ridgway, CO
    There's a square headed, threaded steel plug on the upper front part of each knuckle, grease can be pumped in via this opening :-/
  3. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Yup.. but it is rear aspect, not front on earlier '40s. &nbsp:Don't know what year they changed. Here's a picture from behind the axle on my rig.
  4. 73fj
    73fj Tho at sumbitch in ayer!
    1,058
    Media:
    36
    72
    Mar 16, 2003
    Grande Prairie, Alberta, Canada
    :D crack it open and stick in your gun and pump till full.
  5. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Pump moly grease right?
  6. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
  7. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Great! I went out and found that the side of the axle I was looking at was so covered grime and gunk that I couldn't see the plug. On the other side I could see it just fine. It is on the rear for '74 like dave suggested, got a couple cartridges of moly grease from Napa, goin ta get the pressure washer out, get that grime off and then pump em up!. Thanks again guys.
  8. denis
    denis (O) toyota nut (O) SILVER Star
    1,154
    Nov 11, 2002
    buried in a pile of yota projects
    Mmmh... what's the point of greasing the outside of the birf ? If you really want to grease the birf itself, you have to take it out....
  9. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    I don't know, just wondering, if you keep it full of grease, won't it eventually work its way into the birfield? Also, if you happen to break a birfield, having it full of grease will mean that the broken off bell of the birfield will stick in the grease and not fall to the bottom and prevent you from turning.
  10. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    NO.
    First things first. repack your birfs, then you will understand how they work.
  11. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Ok, but thats gonna have to wait for a few weeks until after I get out of school. For planning reasons, assuming everything goes well, is a birfield repack an under 8 hour job, for a decently equipped shop? (I'm air equipped).
  12. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    It depends on how much snap you have. I know someone that can do a side in a 1/2 hour on the trail! First time around it will take you at least 8 hours to do it right. it's not a timed event though so take it easy and don't rush or you might fawk somthing up.
  13. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Yeah I know how that goes........ :-[
    Problem is I'm always on a time limit cause the parents get pissed when my car is down for maintenence and mods. :mad:
  14. denis
    1,154
    Nov 11, 2002
    It's not as much a matter of time than DIRT ! You'll see what I mean when you do it ;)
    As for external greasing keeping dirt out of the knuckle... yes, that's right, but that's not the way you actually grease the birfield itself...
    :beer:
  15. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Ok I gotcha, for now I'll just fill them up, and then in 2 weeks when I'm outta school I'll take a full day off from work and do a true birfield repack. Also-I know my front axle seals are shot since my diff oil is green(color of the grease the PO used), replacing the axle seal is something to do when you repack a birf, correct? Thanks again for all your cruiser wisdom guys. :bow:
