rusty_tlc
Dain Bramaged Member
What would you do with this 1975 FJ40? I think I posted a similar thread a while back, times have changed and I'm re-visiting this.
The Good;
SOA
Metal Tech family cage
PSC power steering conversion, gear box ported for hydro (I have all the hydro assist parts just not installed.)
Orion 4:1 T-Case
Marlin 2.5:1 Crawl box
ARB Air lockers F&R(need new seals)
Original 2F which will not effing die.
Specialty Tops soft top
Longfield birfs, inners and hubs rings.
Chicago lives less than a mile away
The bad;
No cut and turn.
Lots of oil seepage/leaks; pinion seals, t-case to crawl box, t-case rear main, oil pan, etc.
A tangle of wires from multiple add on of stuff, switches that don't work, just stuff that embarrasses a guy who makes his living doing stuff with Lectricity.
Junk yard mix and match spring packs
Bad skin cancer, enough bondo to make another Cruiser.
20 year old ARB compressor already re-built a couple of times
Original seats, and upholstery which are an embarrassment in themselves
Broken anti wrap.
Issues with the steering linkage clearance
Not much time or money.
Not a lot of welding skills.
Not sure if this is a plus or minus;
Trail Worthy Fab Re-Centered Hummer run flat double bead locked wheels with mil 37x12.5 16.5" Goodyears. These bastids are HEAVY and may have contributed to the last few trail breaks I have had.
Resources:
The hydro assist package
A Sanden AC compressor
Reduction geared starter
Most of the stuff to build a nice swing out tire rack.
A Lincoln "tombstone" AC stick welder
A Harbor Freight wire feed welder
I could probably come up with an SM420 and some FJ55 springs.
I also have a set of Detroit lockers with 4.56 gears in my FJ60, the 40 has 4.11 gears. Pretty sure the FJ60 with 33's would be happier with 4.11 gears and the FJ40 with 37's would be happier with 4.56 gears.
The Good;
SOA
Orion 4:1 T-Case
The bad;
No cut and turn.
Broken anti wrap.
Resources:
