I have a persistent and challenging issue with my FJ80 and could really use some help. Unless off-roading, when it happens consistently, I have a random but harsh POP that comes from the front passenger side of the vehicle. It most often happens when taking a sharp left turn, or braking hard. It's a very loud metal on metal sound.
History:
- Purchased on 7/27
- Service on 9/5
- New front brakes w/ shim
- Repacked front wheel bearings
- Greased front knuckles
- 2.5" OME lift kit installed on 10/2
- Heavies on front
- Mediums in rear
- Sport shocks all around
- Steering dampener
Symptoms:
- POP did not start happening until around the time of the service/lift install.
- During daily use, POP might happen during a hard turn left at moderate speeds (10-20mph).
- During daily use, POP might happen during a hard stop (slam on breaks)
- During daily use, POP does not happen going straight over speed bumps at slow speed.
- During off-roading, POP happens consistently.
- POP resonates in the floorboard and feet, NOT in the steering wheel.
- POP is very loud metal-on-metal sound.
Resolution Effort(s):
- Springs, shocks and dampener inspected by three different sources. Kit install looks good, with one stating the front passenger shock is slightly loose at full tighten.
- One shop mentioned the ABS as the culprit but couldn't articulate exactly why.
- Sway bar greased and tightened. I do not believe it is the sway bar.
- The knuckles and the birfields are completely stock. This includes the trunnion bearings. I had them serviced on 9/5 and apparently they looked just fine.
I suspect something in the hub (bearing, birfield, trunnion) or ABS, but have no idea how to narrow it down and find the actual problem. I don't have a lot of tools and/or time to spend investigating it at home and I'm bordering on desperation (RCV Axle replacement, front end kit from Kurt) or offering a resolution reward...
History:
- Purchased on 7/27
- Service on 9/5
- Heavies on front
- Mediums in rear
- Steering dampener
Symptoms:
