GM Tilt Steering Wheel
Discussion in '40- & 55-Series Tech' started by Straylight, Apr 28, 2003.
  1. Straylight
    Straylight
    87
    Feb 24, 2003
    Have a 1975 FJ40 with SAG Power Steering Conversion. Would like to put in a GM (?) Tilt Wheel. Anyone have any suggestions on what the pitfalls may be. what needs to be done? How do I hang it from the dash and connect it through the firewall to the steering joint I already have on the set-up (universal joint just past the firewall in the engine compartment).
    anyone know how much a column would run from a junk yard?
    Appreciate any input.
    D. Kane
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    Get one long enough to have an easy reach to. My first one was too short. The wipers are a pain to wire. Just use the stock switch. Texican uses the non-multi-tasking handle after he pulls the old one out and throws it in the bushes. They are junk anyway. Very easy to mount to the dash. A pillow block bushing is the best way to mount it to the fire wall. Check out the tech pages.
    Cost is wholly dependant on your area and the individual junk yards. You can check car-parts.com for prices.
  3. Pete112
    Pete112
    19
    Nov 15, 2002
    I bought mine with a Chevy column already installed and I think its great. Its from a '79 Camaro (PO told me) and has a tilt wheel. He made mine look as good as stock. They also added Saginaw power steering when they put on the column. Only thing I think is dumb is the key whole in the column that is now an empty whole because my ignition is in the dash. Also, with the older columns you won't have to worry about having a million non functional switches (wipers, high beams, etc.).
  4. buckroseau
    buckroseau May I have another!!! SILVER Star
    3,307
    8
    Mar 29, 2003
    Northern Minnesota
    I'm doing a ground up resto on my 77 FJ40 right now and I'm putting in a Saginaw power steering kit from Advance adapters. I plan on using a GM column myself. Advance adapters makes a plate/block that mounts in the stock firewall position to give it a factory/professional look, probably easy also. They make 2 different ones, 1 for a 2" GM column and the other for a 2 1/2" GM column.
    If you go that route you would have to find the column first so you would know which one to get? All I have done so far is welded on my plates and got my sector mounted. Awaiting a new tub before I get to the Column stuff?
    Also got my saginaw pump mount for a 2F from Bill Dorry today. Looks very nice and professional, you can tell he is a machiniest. Hopefully I will have some pics of it mounted on my web site in the next few days. :)
    http://ccor.topcities.com
    Matt
  5. pfry
    pfry
    64
    Feb 17, 2002
    I put an Olds 442(1970 If I remember correctly) Tilt column in my 68 FJ40. Also saginaw P.S.
    I use the GM ignition, turn signals, horn and dimmers.
    Those functions wired up nicely to the OEM circuits.
    I copied a few pages from the GM manual for the Olds with the electrical info and made a "cross-over" drawing to mate the OEM with the GM.
    As mentioned by others, I'd keep the OEM wiper and 4-way switches.
    The physical mount of the column was fairly easy. I didn't buy any adapters or other gadgets.
    I can send pix if you want.
    Paul
  6. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Yes I would agree with paul use the ignition on the column and turn ,horn and hazards depending on year of column mine came out of 75 nova with no wipers on column pretty easy wire job and happy with the way It turned out.Hanging it from column welded a 2 1/2" muffler clap on inside of firewell painted it black and no one knows the diff went down to pull a part and grabbed a factory hanger for the dash and cut down welded it and painted It,done in solid works great
  7. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    Post them here if you can...or e-mail them to me. thanks!
  8. pfry
    pfry
    64
    Feb 17, 2002
    Here are some pictures of my column.
    When you go to the junkyard......
    Get the mounting clamps and bolts,
    the wiring, as much as possible, cut it way downstream of all of the connectors.
    Be sure to get the ignition key if it's there.
    While you are under the dash, go ahead and get other goodies like flashers.
    I didn't see aneed for any fancy bearing block where it goes through the firewall. I cut a real good fitting rubber widget from a piece of conveyor belt and use the OEM bolt arrangement.
    It doesn't move a bit. The FJ dash is real stout where the column bolts up.
    Mine has the wheel lock lever intact. It used to hook to the GM floor shift linkage and locked the car in Park when the wheel is locked. It can be cut off if you want to.
    Good Luck
    Paul
  9. pfry
    pfry
    64
    Feb 17, 2002
    a couple of more pictures.
  10. pfry
    pfry
    64
    Feb 17, 2002
  11. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Thats right is was pfry who gave me some of my ideas for mine turned out well 8)
  12. jm
    jm
    75
    Mar 30, 2003
    Matt -- how's your saginaw pump mount look? get it installed yet? pics?
    I'm not happy w/ the setup I have so I'm looking for something better, preferably adjustable rather than using an idler pulley for adjustment.
    Any contact info for Bill if he's still selling brackets?
    thx, jm
  13. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    Don't limit yourself to the GM column. Chrysler, IH and AMC All used and still use GM's columns. This gives you more options
