GM TBI Fuel Lines to stock FJ40 tank
Discussion in '40- & 55-Series Tech' started by 78mustard40, Apr 1, 2003.
  1. 78mustard40
    78mustard40
    17
    Jan 31, 2003
    What have you guys done when hooking up fuel lines from a GM TBI (V8)? What connectors from back of TBI unit (threaded) to stock push on tank connections (78 FJ40).
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,090
    Jan 15, 2002
    Toquerville UT
    TBI runs pretty low pressure....and requires a return line. NAPA sells a repair kit that you can use off the TBI itself then just use GOOD hose clamps to attach some rubber line to the stock tank. Tough part might be locating the fuel pump...
    Not sure where you'll tie in the return since mine is a cell setup tho....
  3. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    Toyota uses a return line too, that's what I used on my stock tank.
  4. 78mustard40
    78mustard40
    17
    Jan 31, 2003
    Thanks Woody, the guy's at NAPA can't seem to find the repair kit # you mentioned, you have that? Put a Holley electric pump high enough up on the right inside frame rail.
    And Gumby u are right, that return line connection is the one I will use on the stock tank.
