Gearmaster Overdrives
Discussion in '40- & 55-Series Tech' started by Bucephalus, Jun 18, 2003.
  1. Bucephalus
    Bucephalus
    5
    Jun 18, 2003
  2. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    Not the Overdrive, but I have the Gearmaster 3:1 gears in my transfer. It howls about as loud as the old SM420. The Overdrive seems to rule out the Cruiser Crawler transmission option since they both take the same spot on the transfer.
    Dave
  3. Greg_B
    Greg_B
    4,291
    50
    Mar 28, 2002
    Dave!
    Did you get the under/under set?  I've a 1:08-3:05 set just installed in a rebuilt H55F.  Not much whine to speak of, though it's still sitting on the bench :D.  Did you just grind out the case a bit and run them, or did you billet the case at all?
    Thanks
    gb
  4. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    Hey Greg!
    Yes, I run the 1.08/3.08 set. You have to grind the case a bit to clear the output gear. &nbsp:Did you recall my post to the DTLC? That hole in the TC has more to do with fitting the wrong '85 parts to an '81 case!
    If I were to do it over, I might spray the case with LineX on the outside to quiet it down :D
    Dave
  5. Greg_B
    Greg_B
    4,291
    50
    Mar 28, 2002
    Hi Dave.
    Nope, total brain fart not recalling it was you that had the gears and blew the case! :-[
    Sulking away now :doh:
    LineX...I was thinking Hurculiner! ;)
    gb
