gas tank
Discussion in '40- & 55-Series Tech' started by wayne_fj40, Jan 13, 2003.
  1. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    I need to figure out what kind of gas tank to run so I can run more than 13 gallons of gas the only aux tank that I've found is thruogh ccot and they want 450 bucks for 22 gallons so I'm not sure what to do I looked at feul cells but I would like to put a small backseat there.any ideas anyone distessed ??? ???
  2. woody
    woody Internet Fireman Staff Member
    10,331
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    Check your local boat dealer or radiator shops and see what a custom tank will run ya...might be surprised what they can do, and at the pricing.
  3. petescoffee
    petescoffee
    1,824
    19
    Dec 29, 2002
    Walnut Creek, CA
    Check out http://www.man-a-fre.com/ . They have an Aux tank as well as a new tank that will gounder both front seats. They are listed under engine parts.
  4. peterbiere
    peterbiere
    10
    Jan 8, 2003
    How do these auxilary tanks attach? I presume in front of the back axel. Is clearance affected? How does the filer work? &nbsp:Does gas route over from the main tank when filling, and then get pumped back over when the main tank is empty?
    I noticed that the Man-a-fre tank can also be set up to supply the engine directly. Why would you want to set it up that way, and how would you fill the tank?
    Is any welding required, or is this something that I can do my self novice).
    Thanks.
