gas for mig welding
Discussion in '40- & 55-Series Tech' started by erfworm, May 28, 2003.
  1. erfworm
    erfworm
    348
    30
    Apr 10, 2003
    So I've got a 175amp Clarke wire welder, that I,ve been using for about 10 years without the gas. This welder has the hook for a gas bottle, what my question is: What kind of gas for different metals and best set up/manufacture for the Clarke? Thanks guys, I'm sick of slag. :G
  2. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    erfworm,
    I use CO2/Argon gas when welding black steel. When welding stainless and aluminum I use straight Argon. I have a Lincoln 175 and to weld aluminum I have to put a plastic (teflon I think) liner in the gun back to the spool....the soft aluminum wire won't feed up thru the metal liner.
  3. denis
    denis (O) toyota nut (O) SILVER Star
    1,154
    Nov 11, 2002
    buried in a pile of yota projects
    ditto what Todd said.
    Ar/CO2 80/20 or 75/25 is said to be the best for mild steel... at least it works fine for me...
    I'm welding steel (solid wire) with the plastic liner, and it seems to work OK for me...
  4. brian
    brian SILVER Star
    7,343
    770
    Feb 7, 2003
    lebanon,pa
    when dealing with blk steel you could use the argon/co2 mix,straight co2 or straight argon, when using solid(bare) wire.
    when using gas shielded flux core ss or blk co2 is the way to go.
    straight co2 will give you a hotter arc but more splatter.
    straight argon will control splatter better.
    can you quess what happens when you mix the two?
    ss you can use straight argon or an argon helium mix and i think there's a helium/argon/co2(it might be nitrogen instead of co2) mix. MIGing ss you're better off with the argon/helium mix. for best results with stainless steel always try to drag the puddle down hill.
    aluminum, i try not to mig when ever possible.
