fuel inj. problems
Discussion in '40- & 55-Series Tech' started by archie, May 7, 2003.
  1. archie
    archie
    1,183
    3
    Dec 14, 2002
    NW side of chicago
    I have a non-cruiser related problem with my fuel injector on a 91 Mercury Tracer with 93k. I am not getting any fuel into the cylinders 1 and 4 even when trying to flood it. I am getting fuel into the other 2 and 3(center). What is the probability that it is a clogged injector or and electronic problem? Haven't checked for fuel pressure but I assume that if 2 cylinder get fuel there should be no problem. I do know that it is getting pressurized (fuel pours out when starting when lines disconnected). Before I send the injectors out for cleaning do you think it might be electronic related because two cylinders are not recieving fuel? thanks for the input.(88 fj62 w 201k will probably need inj. cleaning also.)
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    You need a noid tester to see if the injectors are getting a signal from the PCM to fire. You could switch the injectors and see if the problem moves.
    How are you trying to flood the cylinders? About the only way I can think of off the top of my head is to pull the ECT to make the car think it's really cold.
    Does the Tracer have the 1.9L? If so, I have a parts car that just came in. You're welcome to the injectors and PCM if you want.
  3. archie
    archie
    1,183
    3
    Dec 14, 2002
    NW side of chicago
    What luck finding somebody in the Chicago area that has the exact car that's a cruiser fan. It is a 1.9 and I will try swapping injectors before sending them out for cleaning( great idea). I tried flooding the engine by stomping the accelerator a few times while trying to start it(I think it possible even with fuel inj??). The engine wants to turn over only when I try to start it for the very first time but after that only cranks and sparks. How did you get the parts car?
  4. Yoda
    Yoda
    400
    Feb 23, 2002
    North Bend, WA
    Some injected vehicles fire their injectors in pairs. Example 1 and 4 fire at the same time, and 2 and 3 fire at the same time. If this is the case with yours (I think my old 89 escort GT 1.9 was this way) it could be the PCM or a common wire to the (2) injectors. I no longer have the book for that car so I can't look it up. The fuel rail is common to all injectors, so pressure to 1 = pressure to all. Check your fuses too. Each set of injectors may have its own fuse. The suggestion of a "noid" light is good. They are less than $10, and tell if the signal is good to the injectors (flashing LED that plugs into injector harness)
