Fuel Gauge/Sender Problem
Discussion in '40- & 55-Series Tech' started by tkerkela, Aug 25, 2009.
  1. tkerkela
    tkerkela
    21
    Jul 13, 2009
    Republic, Michigan
    I have a 76 FJ40 and I have an aftermarket RCI fuel cell and sender. I filled it up earlier in the week and there was just about 5 gallons of fuel or so in it and it was reading about 1/2 ot 3/4 of a tank. The thing is, the tank is 19 gallons. Something isnt right at all. Yesterday I filled the tank right up as much as it could hold and it read totally empty. I have no possible idea what it could be, its almost like its reading backwards or something. Help is much needed and appreciated.
  2. JB740i
    JB740i
    362
    Sep 3, 2007
    Citrus Springs, FL
    Seems like the first thing is to always check the ground. I know nothing about fuel senders beyond that. But see if you can find the ground for the sender.
  3. dgangle
    dgangle total rice SILVER Star
    4,001
    3
    Nov 24, 2004
    Heart of Dixie
  4. nedhed
    nedhed
    7
    Apr 2, 2009
    Nederland, CO
    Fuel level senders in the fuel tank don't all work the same. Many aftermarket gas tanks use a GM 90 ohm sender. I'm not sure what the FJ fuel gauge is set up for, but it sounds like a mismatch between the sender and the gauge to me. I'm sure someone else can chime in and provide better details.
  5. PatFJ40
    PatFJ40
    133
    Aug 16, 2009
    Tri-Cities WA
    JB is on the right track. Check to make sure your sending unit is grounded. How many wires are going to the unit? If there is only one you can stick it straight to a ground point and your gauge should peg all the way over. If it does your wiring and gauge are ok. Let us know what you find.
  6. dgangle
    4,001
    3
    Nov 24, 2004
    Heart of Dixie
  7. tkerkela
    tkerkela
    21
    Jul 13, 2009
    Republic, Michigan
    There are two wires to the fuel cell sender. One ground and one positive. I think the problem might be the ohms. There is a GM sender in it that goes from 0 to 90 ohms and the FJ40 senders are way less than it i found out. I might just try to put a FJ40 sender in the tank and see if it works. Any other help is appreciated.
  8. crushr
    crushr
    882
    1
    Apr 12, 2006
    Concord, CA
    The ohm range must match between the sender and the guage. The factory FJ40 fuel gauge uses an unusual ohm range, which no aftermarket senders match. Use an OEM sender or replace the gauge with an aftermarket which matches your sender.
  9. dgangle
    4,001
    3
    Nov 24, 2004
    Heart of Dixie
    the last post is right on the money.
    I did confirm the sending unit resistance reading on the link I posted above are correct per page 12-27 of the FSM. Gauge diagnostics is covered on page 12-26.
    BEWARE of using the info from Cool Cruisers as it is WRONG. They appeared to only state the acceptable range in variance of the readings, not the true ohm measurements. Short of pulling my sending unit and actually measuring, I'd bet money on the FSM info anyday.
    Per http://coolfj40.stores.yahoo.net/gastanfj19th.html
    "The fuel tank sending units range is from 2.1 ohms to 6.5 ohms. Tank Full 2.1 ohms. Tank 1/2 Full 4.5 ohms. Tank Empty 6.5 ohms"
  10. cruzerman350
    cruzerman350
    510
    Jan 31, 2005
    morro bay,CA
    that cool cruisers website is correct. above where you found that it says "# FYI: Float Position Reisistance is as follows:
    # Full -- 17+/- 2.1 Ohms
    # 1/2 -- 45+/- 4.5 Ohms
    # Empty -- 120+/-6.5 Ohms
  11. dgangle
    4,001
    3
    Nov 24, 2004
    Heart of Dixie
    The website info has been corrected. I sent them an email pointing this out to which they replied thank you.
  12. middlecalf
    middlecalf
    366
    Jul 20, 2004
    Sweet, Idaho
    Is there an aftermarket fuel gauge that will fit the form factor of the FJ40 gauge panel, per chance? I'm getting tired of adding gauges all over the place plus running out of room - right now the only gauge in my original cluster I have working is the ammeter (still trying to figure out why the new speedo cable doesn't work).
  13. dgangle
    4,001
    3
    Nov 24, 2004
    Heart of Dixie
    I am unaware of anyone that has put an aftermarket gas gauge in the stock cluster. There was a reccent thread about mounting small aftermarket gauges into the stock cluster but the person reused the OE gas gauge. There are also plenty of people who have put entire different clusters in that utilize all aftermarket gauges. The current ROTW has done this IIRC.
  14. middlecalf
    middlecalf
    366
    Jul 20, 2004
    Sweet, Idaho
    I saw the thread about upgrade kit for mounting aftermarket gauges, pretty darn cool. But like you said, the fuel gauge remained stock. So here's another question, I know my stock fuel gauge "works" (it climbs to full when shorted across the battery). Has anyone found an aftermarket sender that works with the original (early FJ) fuel gauge?
  15. dgangle
    4,001
    3
    Nov 24, 2004
    Heart of Dixie
    No. Our's use a range that has been said to be unique.
    Most any fuel guage is only an approximation of the liquid level, especially in something +35 years old. With my poly tank full and stock sending unit, I can drive 75 miles B4 the needle moves off "F". Another 50 and it is on "E". I accept it 4 what it is and am glad it works at all, albeit inaccurate.
  16. Downey
    Downey SILVER Star
    2,755
    172
    Jun 5, 2007
    Brea, Calif.
    Your 1976 uses a 120 ohm empty, 17 ohm full sending unit. If you can not find one for your aftermarket tank, I can help---PM me.
