front heater blower
Discussion in '40- & 55-Series Tech' started by milesstarkey, Feb 8, 2003.
  1. milesstarkey
    milesstarkey
    353
    Oct 15, 2002
    i can hear the blower running, but i don't feel any air movement. with it being -5 here in iowa, i need some heat. does anyone know where i can get a new fan, if that's the problem?
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    You didn't mention the series, but assuming it's a 40, there are a few things that could be happening.
    Pull the plastic plenumn that runs from the blower motor box under the glove box to the heater box. You can now see the squirrel cage for the blower motor. Turn it on and verify that it's blowing at the various speeds. Now look in the heater box at the top of the heater core. They often get plugged up with mung. It's not too hard to pull the whole assembly, but if you don't want to mess with draining the coolant, you can clean it best you can through the hole.
    The other big thing is the seals on the heater doors and the doors themselves not moving correctly. Check to see where air might be leaking when the little flaps are where they are supposed to be when they divert air to where you want it to go.
    Also the heater duct tubes that go from the box to the defrost ducts fall off and get loose. There are ne ones available or you can replace them with other flexable tubing.
    Lastly, the heater systems on 40s generally suck anyway. You can replace it with a JC Whitney or Vintage AIr unit for better perfomance.
  3. milesstarkey
    milesstarkey
    353
    Oct 15, 2002
    thanks. it's a 71 fj40. i'll check all that out.
  4. FJ40Dude75
    FJ40Dude75
    248
    Nov 12, 2002
    If you want heat goto yhe junk yard and get a conversion van rear heater run it to the rear coolant lines and whala you have a blast furnace of heat i pulled my heater core out and just use that
