Dissent
Questioning my life choices...
I used a digital angle cube to determine the angles of my flanges and after zeroing the cube on the concrete garage floor, the front pinion flange is 6.4 degrees and the transfer case flange is 3.2 degrees. When I place the cube on one flange and zero it, then move it to the other flange, it reads a delta of 9.6 degrees which jives with the above numbers.
I removed my front OEM shaft and replaced it with a DC shaft a few weeks ago after lifting my 97 LX450 with TJM 50mm Heavy Linear springs with 30mm Poly Spacers and Slee caster correction plates, attaining a solid 4" lift on all corners, and began experiencing driveline GRRRs in the front. I've had the front end aligned by the dealer with no impact.
I've adjusted the rear pinion/transfer case flanges perfectly parallel using Metal Tech adjustable Lower Control Arms and installed new OEM u-joints then balanced the rear shaft and all vibrations are gone in the rear.
I am left with a vibration in the front between 45-80 which is very noticeable under load. I pulled the front shaft today and measured the angles. A test drive with the front shaft off is glass smooth up to 80 (couldn't go much faster tonight).
I'm not sure what to do. The DC shaft doesn't appear to be parallel to the pinion with 0 degree deflection as required for a DC shaft but the flanges aren't parallel to run an OEM shaft.
What can I do outside of running a part time 2WD kit? I'm literally at my wits end here.
