Front Driveline from a Mini??
Discussion in '40- & 55-Series Tech' started by 1Fine40, Sep 8, 2003.
  1. 1Fine40
    1Fine40 Rust Buster SILVER Star
    780
    13
    Aug 25, 2003
    Wild Idaho
    So after a several :banana: :banana: :banana: job of cutting and turning the front axle..(I didn't do it, but had it done by W) I now need a CV for the front driveline to try and reduce vvvvibbbration when driven on the street with front end engaged. (Kinda nice for winter ya' know. ::)) Has anyone used a minitruck front DL from like a late 90's model and just lengthened the tube as required?? I'm sure I'd need to redrill the flange somehow, but will that work?? How's about it? Anybody done this apparently "cheap" fix??
  2. hendo
    hendo
    181
    Sep 10, 2003
    san fernando valley
    how much did it cost you to have the axle cut and turned ? i am in the middle of trying to do it myself but haveing a hard time.thanks for any info you can give me
  3. 1Fine40
    780
    13
    Aug 25, 2003
    Wild Idaho
    Over the Hill 4X4 in Portland Oregon did it. was right around 2 bills plus shipping. He used my core housing though.
  4. SPRDAV
    SPRDAV
    82
    Aug 11, 2003
    W did mine too. I haven't had any problems with vibrations, except when I turn with the locker engaged. That's to be expected. The vibrations might be a bearing the transfer case?
  5. 1Fine40
    780
    13
    Aug 25, 2003
    Wild Idaho
    Nah, I think the t-case bearings are fine...The ujoints are now out of phase with each other cause the pinion points toward the T-case flange....that's why I need a CV ;)..I just don't wanna pay big $$ for one if I don't have to. ::)
  6. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    What year 40? Do you have large or small flange?
  7. 1Fine40
    780
    13
    Aug 25, 2003
    Wild Idaho
    It is a 78' 40, so I think the flanges are large....??
  8. 60serius
    60serius
    11
    Jul 28, 2003
    HJ60 came with a double cardan front shaft but has the small
    flanges. I used one on my FJ62 when I did the SOA.
    The Hilux (mini) Shaft can be used and has Greater flex in the uni's
    The flanges are easy to change they nearly all fit each other
    The HJ60 shaft is common in OZ and I think Canada But I'm
    not sure about The US
  9. 1Fine40
    780
    13
    Aug 25, 2003
    Wild Idaho
    Hmmm, I don't think there are any HJ-60s normally in the US, unless they have been imported specially. I wonder if the FJ-60 or 62 front shaft would work?? At any rate, it might only need to have the flange re-drilled to fit my flange.
    Thanks for the ideas.
  10. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    78s are large flange so I think you need the 84 Toy mini front shaft. The CV end should bolt up.
  11. hendo
    hendo
    181
    Sep 10, 2003
    san fernando valley
    i am in the middle of trying to rotate my front axle but haveing a hard time scared of cutting too deep ,i am thinking of useing a big crow bar to try to twist the thing ,any ideas?also thinking about putting bigger birfields in so i will have to do some grinding,i have a 76fj any ideas?
  12. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    hendo - did you see Woodys article in the tech links? Good info and pics too.
  13. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    [quote author=hendo link=board=1;threadid=5066;start=msg41034#msg41034 date=1063515982]
    [/quote]
    Use a big pipe and just stick it through the king pin bearing holes and twist. Make sure you leave some old bearing races in there for the pipe to push against!
