Front drive shaft rubbing on crossmember
Discussion in '40- & 55-Series Tech' started by jzilla, May 19, 2003.
  1. jzilla
    jzilla
    1,633
    44
    Feb 26, 2003
    Edmonton, Alberta (for now...)
    Just put a 5spd in my 81BJ60 as well as 5spd driveshafts.
    I have 33's and 2.5 inch belton lift which puts you up quite a bit higher than that.
    Can spin driveshaft by hand and it does not rub.
    But when hubs are locked and it is driven it scrapes crossmember. Already lost part of a zerk ( grease fitting).
    Please help.
    thanks
  2. kreaves
    kreaves
    9
    Apr 5, 2003
    When I had my 60 I flipped the front driveshaft end for end. This puts the slip part of the driveshaft at the transfercase end. Only works though if you don't have a CV driveshaft. Other than that you could trim the crossmember and then reinforce it.
  3. jzilla
    jzilla
    1,633
    44
    Feb 26, 2003
    Mine has cv.
    guess I'll have to cut and weld.
  4. jzilla
    jzilla
    1,633
    44
    Feb 26, 2003
    Found 5spd crossmember which has more space for driveshaft.
