front axle service writeup?
Discussion in '80-Series Tech' started by SeanAndHis80, Aug 19, 2003.
  1. SeanAndHis80
    SeanAndHis80
    561
    2
    Apr 10, 2003
    Chester, NH
    Didn't someone write up an elaborate post on the front axle service?
    I'm hearing the clicking now :(
    I got the FSM from Jim and have been reading up on it (Jim kindly highlighted the needed section with some grease ;) )
    I am ordering parts from Dan, any hints to make this go smoothly?
    Thanks!
  2. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    check the tech page, i'm sure the front axle service is there, under axle/drivetrain
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,566
    2,892
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Sean,
    Bad- is correct. It is in tech links and Jim was the author. As you have his original manuscript ;), all should go well.
    If only you had his socket.......... ::)
  4. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,098
    Jan 15, 2002
    Toquerville UT
  5. SeanAndHis80
    SeanAndHis80
    561
    2
    Apr 10, 2003
    Chester, NH
    [quote author=woody link=board=2;threadid=4439;start=msg33171#msg33171 date=1061301607]
    http://www.ih8mud.com/tech/birf-repack.html for the direct link and the "search/browse" challenged...hehehe
    [/quote]
    I searched but did not browse ::) my bad.
    Many more stupid questions to come next week ??? I am sure.
    Thanks all.
  6. nakman
    nakman addict. Supporting Vendor
    2,173
    159
    Jul 30, 2003
    Broomfield, Colorado
    You're welcome to check out how I did mine, http://www.nakari.com/80/birfield.html I also have a link to Jim's writeup in there, same as the one posted above. Have fun, no stupid questions, right? -tim
  7. Macondawg
    Macondawg
    24
    Apr 4, 2003
    About how long would this take a novice (with half drunk supervision)?? I really need to do this but my cruiser is my daily driver so i can't let it take more than the weekend. Thanks
  8. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    First time around will probably take you 1 to 1.5 days. By the 5th time you'll have it down to about 5 hours :).
  9. Curran
    Curran SILVER Star
    824
    5
    Mar 27, 2003
    Frederick, MD
    what does this clicking sound like? ??? Every now and then I hear a clicking noise but each time I check I find a rock stuck in the tire tread. Always makes me a bit nervous 'cause I have no clue if the previous owner had them services or not and I'm at 90K miles.
  10. cruiserdan
    20,566
    2,892
    Mar 27, 2003
    [quote author=Curran link=board=2;threadid=4439;start=msg33343#msg33343 date=1061346143]
    [/quote]
    Um, well, clicking. ::) in some cases you may get a rumbling effect. It generally intensifies in turns as the birfs are loaded.
  11. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    what does this clicking sound like? [/quote]
    If your butt tenses, your wallet gurgles, you get cold chills and you hear the click, then get ready big boy, the mightly :banana: is coming in.
    Not trying to scare you too much, ;) :D beware that most guys on the 80's list talk about clicking later find out a rock was in the tire tread (if they had swampers, it would be a crunch crunch crunch instead of the lil mtr click clidk click :flipoff2: :flipoff2: :flipoff2: :flipoff2: :flipoff2: :flipoff2: :flipoff2: :D
  12. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    [quote author=cruiserman link=board=2;threadid=4439;start=msg33219#msg33219 date=1061309967]
    [/quote]
    My first and only time took over a week... ::)
    But, you need to take into account that I am somewhat challenged when it comes to my mental abilities... :D
  13. Riley
    Riley
    1,613
    10
    Jun 20, 2003
    Fort Langley, BC
    Having never done this service I have learned that you need to check the axles for wear in the area that the seal sits. If there's wear you will need to reman them. This is take more time. :'(
    There's a good post from Sleeoffroad on this.
    Also when I plan on doing this I was going to just replace the front wheel bearing as well since I'm in there.
  14. SeanAndHis80
    SeanAndHis80
    561
    2
    Apr 10, 2003
    Chester, NH
    what does this clicking sound like? ... [/quote]
    It sounds like a racheting noise. It (currently) only happens when I am turning left and accelerating hard.
  15. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    The best way to not have to check the birfs for wear where the seal sits is to go ahead and buy a set of longfields to throw in when you do the service. :D
    I just did the same service on my 40 for the first time and I started Sunday around 3, worked till 12:00 on sunday, then worked from about 9am monday to 3am tuesday. But I had to go to soccer practice and some other stuff on tuesday. I estimate 20 hours of actual working garage time. Accomplished in 1.5 days. :D
    Its not an 80, but its nearly exactly the same thing, as far as this service is concerned. I bought a 20 gal parts washer before I started, and if you have room I would reccommend this, saved a lot of time, mess and rags.
  16. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    aren't longfields treated to be softer, less brittle? would this run to increased wear in them, not an issue in 40's, but is in the full time 80's
  17. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    [quote author=CruisinGA link=board=2;threadid=4439;start=msg33471#msg33471 date=1061391785]
    The best way to not have to check the birfs for wear where the seal sits is to go ahead and buy a set of longfields to throw in when you do the service.[/quote]
    It is not the birfield that has the wear, but the inner axle. Also the dust seal area on the spindle. The machined part of the birfield runs in the bushing.
  18. sleeoffroad
    6,056
    531
    Mar 27, 2003
    [quote author=bad_religion_au link=board=2;threadid=4439;start=msg33473#msg33473 date=1061392136]
    [/quote]
    Correct, they are not an option for street use.
  19. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    woo hoo i'm learning something
  20. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    [quote author=sleeoffroad link=board=2;threadid=4439;start=msg33517#msg33517 date=1061401716]
    [/quote]
    Ok, not a problem, you'll have to do a part time 4x4 convo at the same time then. :D
    C'mon guys think outside the box ::) :flipoff2:
