frame paint?
Discussion in '40- & 55-Series Tech' started by dylan, Apr 14, 2003.
  1. dylan
    dylan
    246
    Dec 23, 2002
    what kind of paint should i paint my frame with? it will have a hard life consisting of road salt, snow, mud and sand.also i want to fab up some tube doors for my 76 fj40 .anybody got pics? that'd be great. thanks :beer:
  2. buckroseau
    buckroseau May I have another!!! SILVER Star
    3,307
    8
    Mar 29, 2003
    Northern Minnesota
    I'm no self proclaimed expert, but I used PPG DP90 black self etching primer after I completely sandblasted the frame.   Then for paint I used PPG's MTK Omni AU (black) single stage urethane.    I think it turned out really good.   I live in Northern Minnesota where salt is used more than asphalt.
    You can see pics on my web site
    http://ccor.topcities.com
    Just click on "Matt's cruiser" on the side bar, pics of the frame will be down at the bottom. You can click on the pics to enlarge them.
    Matt
  3. Corbet
    Corbet Speski OffRoad LTD. Supporting Vendor
    3,727
    615
    Oct 22, 2002
    Durango, Colorado
    POR 15. Type that into any search engine and you will find the web site. It stands for paint over rust. I just got done using it on my floor after a friend of mine used it with great results.
  4. Gus
    Gus SILVER Star
    1,125
    Media:
    8
    63
    Apr 13, 2003
    Ridgway, CO
    :) I second Corbet on the POR15, I coated my entire frame, axles, steering components, engine, transmission and almost everything else that was made of metal with the stuff, and it's pretty tough. It doesn't stick to aluminum very well, I coated it on the underside of my aqualu tub and it peels off with out much effort. As long as you follow the directions and take advantage of the tips page supplied with your order, you should get good results. Restomotive labratories(the makers of POR15) are very cool people to do bussines with and shipping is really fast(two days to get to Vermont), they also make a lot of other really cool products. :D
  5. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    When I get around to mine, I am planning the belt, suspenders X 2 approach. Sandblasting, POR15, 3M rocker schutz, urethane paint. The only thing I need to check is the compatability between the POR15 and the schutz. If this doesn't keep the salt demons away....I'll give up and build a stainless frame :eek:
  6. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    DP90 and Frame paint. Looks good and is marine grade. Even the roads in Chicago aren't that salty.
    I DP90ed the tub too. That was overkill. That stuff is a beotch to sand.
  7. Sparky_Mark
    Sparky_Mark
    191
    Mar 13, 2003
    Raleign / Durham, NC
    Dylan,
    Coming from the auto industry in Detroit - If you're going to do it once, I'd have to vote for previous posts for PPG's DP90 primer, or CRE 904 primer. You can then consider a good top coating ( I used CRE-904 then AUE-300, but the CRE primer does not require a top coat).
    I am a believer in testing and standards. It makes me feel uncomfortable to purchase products without being able to see comparable test data between the choices. This is why I am very weary of "aftermarket" products - they don't have to do any testing (standardized), they just have to convince you that their product will satisfy your performance needs. You won't know until it's too late if it doesn't. BUYER BEWARE.
    So if you're spending a lot of time preparing the surface, coat it right the first time so you don't have to do it again. First things first - get rid of the rust. I used a home made presurized sand blaster that worked great for removing scale and rust. It was made from a propane tank, or you can buy one for $70 or so if you don't want to spend the time to build it.
    After the prep is done, which was most of my time, you're ready for the coating. I used PPG's CRE-904 epoxy primer that has excellent resistance to the 96 hr humidity test and the 500 hr salt spray test. It also shows good resistance to solvents and chemicals. Here's the link to the product index for PPG:
    http://www.ppg.com/cr-refinish/phase1/frmFindProduct.asp
    You may consult with Sherwin Williams and DuPont as well for some other "validated" choices. These companies sell to OEM's like GM, Ford, and Chrysler so they are required to show test data before their coatings make it on 500,000 vehicles.
    While doing some internet searching, I also found this site that may be of some interest to you. This gentleman has some very good points backed up with some simple chemistry (if you remember back from High School or University Chemistry class). He does a home made comparison on several products. It's not industry standardized testing, but he does the same test on all the products.
    http://www.geocities.com/goodytommy/rust/
    ... Just my opinion, good luck with your project...
  8. ckolloff
    ckolloff
    134
    Feb 28, 2002
    Check out magnetpaints.com also do a search in this forum for their product "chassis saver paint". As a result of that post I contacted eric at magnet paints and he was THE BEST to deal with. He was honest, helpful, answered emails promptly, and completely hooked us up here at the high school I work at! :D
    Basicly their product is very, very similar to POR15 but about 30% cheaper. I have used POR15 and it is great, everyone I know who has used it agrees. I will be sure to let you know if this product holds up as well, but judging from the formula it should. Check them out. Deal with Eric and let him know Chris from Westlake High sent ya.
  9. Trevor
    Trevor
    883
    1
    Mar 11, 2002
    How much does the PPG cost? Is it more or less than POR15?
  10. axlechassis
    axlechassis
    237
    Mar 1, 2003
    Wasilla/Bangkok
    If you have any rust swelling in the rear frame section or along the boxed section of frame you will want to spray something on that will soak in and arrest the rust. The australians periodically spray a mixture of diesel and fish oil. Diesel works by itself but only lasts acouple of months less in really wet salty environments. I've been trying some aviation corrosion products with favorable results. ACF50 or CorrosionX. Both weep thier way into the seams. These products are a little spendy like $15 a can. On my airplane I buy the the ACF50 by the gallon and hose it into the wings with a solvent sprayer.
    POR15 is great stuff I agree but is alot of work to prep properly for, all the loose rust has to be gone and it wont wick into those problem seam areas.
    that spray on stuff is easy to put on and gets into the problem areas very well.
    I suppose if you wanted the cheapest possible way is try mixing some synthetic motoroil with the diesel and hose it on with a garden sprayer that will stop any further rusting.
  11. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    I'm a fan of the POR,BUT it only sticks to areas that have at least some oxidation. If you have sandblasted, Wipe it down with some Metalprep or, on the cheap, some CLR or dilute Muriatic acid. That'll give your bare metal a nice yellow color, depending on humidity, then the POR will stick.
    The parts of your frame that are exposed to UV will go flat. Won't hurt the rust inhibitive qualities of the POR, but won;t be pretty anymore.
    To get a topcoat to stick to the POR, you can buy their intermediate Bonding stuff or just sand the POR with like 320 the use the PPG product.
    BTW you can thin the POR with some lacquer thinner and I beklieve it WILL seep into those lap welds and otherwise tough places.
    When the thing is done, miw 50/50 boiled linseed oil and turpentine and spray it every where you can on the underbody.THAT will soak in everywhere.
    JMHO
    Ed Long :)
  12. dylan
    dylan
    246
    Dec 23, 2002
    thanks everyone. id like to do what sparky mark said but im only taking the bed off(fj45 lwb pickup) and i have a can of por 15 and a bottle of metal ready left from my fj40 frame off project. i just wanted to see some other options
  13. Sparky_Mark
    Sparky_Mark
    191
    Mar 13, 2003
    Trevor,
    The PPG primer is a 2 part system, CRE-904 ($50 per short gallon) and CRE-91 catalyst ($25 per quart). A gallon would go a LONG way. One draw back is that the CRE-904 only comes in short gallons (3 quarts), and the CRE-91 only comes in quarts. It's part of their Light Industrial Coatings, so thier consumers are in need of large quantities. You could easily do the frame with a high film build with 1 quart of mixed material.
    Also, once opened, the CRE-91 catalyst will start to flash. You have to use it up in about 2 weeks (if you keep it cool).
    The Urotec coating has 3 components, the AUE-300 is $30 per short gallon, the AUE-301 (catalyst) is another $30 per quart, then the UA-11 (Urethane Accelerator) is $23 per pint. This all makes a gallon of material. Same deal on the flash time for the catalyst. Note that you don't need to top coat the CRE-90x if you don't want to, but it only comes in 2 colors - gray and red (x=4 for gray, x=7 for red).
    If you do want to top coat the primer, you have to do it in 4 days or less, or else you have to scuff the finish and reprime. After the first use, I sand blasted a bunch of parts and used up the primer on the small stuff - I didn't want to throw any unused stuff away because it is a very good coating.
    Enough babbling, sorry. :slap:
    Hope it helps....
  14. Erics75
    Erics75
    81
    Jun 14, 2002
    Has anyone here powder coated a frame. I know of a shop here that does it and I know its pretty stout and am thinking of going this route.
  15. Gus
    Gus SILVER Star
    1,125
    Media:
    8
    63
    Apr 13, 2003
    Ridgway, CO
    Powdercoating can be pretty tough if done by someone with experience, I've heard the baking process(after the part has been coated) plays an significant role in how well it comes out. :-/
