my idea is this, weld two pieces of pipe (vertically) one at each end of the rear frame crossmember install poly spring bushings in pipe. build rectangular steel piece with hinge on each end to fit over pipe with bushings.bolt one end and the other with a removable pin. then build frame on rectangular piece to mount spare tire just above hitch. are the bushings a good idea? will this be strong enough?
