Frame Dimensions
Discussion in '80-Series Tech' started by Aaron, May 6, 2003.
  1. Aaron
    Aaron
    5
    May 6, 2003
    Hello,
    I am wondering if anyone out there would be able to get me Fj80 frame dimensions. I'm interested in as many different numbers as you have. Mostly I'm looking for rail spacing, max and min rail cross section. Any pictures of a bare frame or rolling chassis would be really cool as well. Thanks.
    --ASH
  2. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
  3. Aaron
    Aaron
    5
    May 6, 2003
    I'm thinking of building up a hybrid. Have pretty much decided on using fj80 axles, and probably an old land rover body that I have. Just trying to figure out the frame. I was thinking of the using an fj80 frame because it seems to have a better stock suspension design than any rovers I've looked at. So, I'm just trying to figure out what the most appropriate frame would be.
    --ASH
  4. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    Hey aaron,
    let me post back later and see if I have the proper factory specs on a frame set in my frame machines database. The only question is what model year frame are you looking at, there is very little difference between the 91-97 model years but there will be some discrepancies in the suspension mount and body mount areas. post back with model year and I will try to pull it up then.
    Dave :beer:
  5. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    Let's see, you wanna 80 frame, axles and suspension. ::)
    Why not just make it easy on yourself and build a Cruiser? You already know that they have superior axles, frame strength, suspension, yada yada yada. I could go on but you probably get the point. Do you have a really bitchin strait bodied aluminum British thing that you just can't seem to get rid of and can't do without the awesome Lucas electronics? If all you have is a body then why would you want that to be your starting point? If it's like an old 110 than why not use everything you have and just through in a G.M. drivetrain to a set of Dana 60's and be done with it? Sorry I don't mean to be snide or snooty but its kinda like putting a sack on Cindy Crawford’s mug. If you’re lucky enough to bang her why would you want to cover it up. Besides gravy parts like that should be left with Cruiser dudes...
  6. Aaron
    Aaron
    5
    May 6, 2003
    Phaedrus,
    I'm probably looking at a '94 frame. Any dimensions you have would be appreciated.
    Moralien,
    Ok, I now realize that I shouldn't have mentioned anything about a Land Rover on a Toyota website. I personally don't have any loyalties when it comes to manufacturers. That said I'm planning on using a Rover body for a few different reasons. First, they are primarily aluminum. I live in the northeast, and most sheet metal here gets rusty after 5-10 years. Aluminum just has better resistance to salt, etc. Also, an aluminum body is going to be lighter weight. Next, Land Rover bodies are very simple. I'm planning on doing a fair bit of body modifications, starting with fewer complex curves will be a great help. As far as 60's go, I'm personally not a huge fan. Yes they are beefy, yes they are popular. However, they are also heavy, crudely made, and only have a single u-joint in the steering knuckle. I'm looking for a rig that will be good on and off road. I'm not interested in a front axle that will make the truck buck and jump while turning sharp corners in four wheel drive. As for Lucas electrics, I never mentioned how it was going to be wired. I could go on, but suffice it to say that I'm only looking for a little tech information. I'm planning this project out slowly, to my personal tastes.
    --ASH
  7. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    aaron
    will try to download specs in the morning, my machine is havig issues.
    Dave :beer:
  8. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Here are a couple from the 1994 FSM
    [​IMG]
    [​IMG]
  9. PHAEDRUS
    PHAEDRUS
    2,036
    Mar 31, 2003
    Ok I give
    Chiris you are cooler than I am. Aaron let me know if you need more info but the fsm diagram has more info than my database.
    Dave :beer:
  10. CDN_Cruiser
    CDN_Cruiser
    1,047
    Mar 27, 2003
    Aaron:
    Sounds like a very cool project - please come back and post some pics during the build process! While I love my truck, I also really like LR :eek:
    I drive by a very rare - at least in Canada - LR Crew Cab on my way home and I LOVE the look of it and would love to own it (not as a daily driver). If had a had a bit more cash (does anyone not say this?), I would stop and offer the guy some $$ to buy it! I dropped by Rovers North a few months ago and had a great time.
    Cheers, Hugh
  11. landtank
    landtank SILVER Star
    18,425
    601
    Mar 27, 2003
    Groveland MA
    Well Aaron you got quite a project there. My buddy has a 87 Range Rover and I can tell you the bodies aren't all that great. First the floor is steel, the hatch is steel and the tail gate is steel. Have you heard of electrolisys?. The bodies un like a Cruiser's are dead weight and add no structural strength. A LCs body is reinforced steel and when bolted to the frame adds stiffness. Stand alone the Rover frame is stronger than a LCs because of internal webbing in the box frame. Son if you are going to use a Rover body it would work best on a Rover frame. Also the Rover has trussed axles as does the LC. Sounds to me your building a non-resellable money pit.
    Good-Luck
  12. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Sounds like what my wife says everytime I start a new project :)
  13. Aaron
    Aaron
    5
    May 6, 2003
    Chris,
    Thanks for the info. That's more dimensions than I could haave hoped for.
    Dave,
    Looks like Chris beat you to the punch. Thanks anyway.
    Landtank,
    I'm not using a Range Rover because they have so much steel. They are basically a steel bodyshell with a few aluminum panels here and there. The older Land Rovers were built much differently.
    I believe you were talking about Galvanic Corrosion, not electrolysis. Electrolysis is a process to remove rust or hair depending upon who you are talking to.
    --ASH
  14. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    Maybe the point Tank was trying to make was if you started out with any hair on your head your not likely to keep it after a PITA project like this. :-*
  15. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    Take the best parts from a Landcruiser and the best parts from a Landrover - put them all together and what have you got? A Landcruiser. :slap:
  16. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    HOLY CHIT! I can't belive I just saw those words typed by a Brit :bow:
    Spoken like a true Cruiser Head....
    Cheers :beer:
  17. landtank
    18,425
    601
    Mar 27, 2003
    Groveland MA
    So Aaron are you using a 109 then? And call it what you want but those Rovers rot to hell pretty quickly inb thise areas.
