Flunking the smog test
Discussion in '60-Series Wagons' started by Mike S, Sep 17, 2003.
  1. Mike S
    Mike S
    2,537
    8
    Aug 19, 2003
    OK, I took my new (old) FJ60 Cruiser to the smog station this evening, flunked big time. Gross Polluter, they called me.
    My heart is broken. But I will continue onward. Perhaps my carburator is crap? Perhaps the test is crap? Dunno. I know that the TLC is targeted in the state of CA. What is my cure, if any are available? I am now certain that the guy who sold me this otherwise pristine 60 had the same problem, and was not man enough t face it.
    Suggestions?
    Mike S
  2. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    Wherever the truck stops!!
    Try a tune up, clean air filter and if you're still worried wait till you're almost out of gas and dump a bottle or two of gas line antifreeze into the tank and maybe you'll make it.
  3. 60wag
    60wag SILVER Star
    1,912
    26
    Jun 25, 2003
    Boulder, CO
    Its most likely that some on the smog hardware isn't functioning. If you have the time and the interest, get a Toyota emissions manual are start testing stuff. Otherwise find a Cruiser mechanic in your area who is familiar FJ60 emissions issues. Did you just buy the truck? Doesn't CA require the seller fix emissions issues before the sale? Colorado requires this.
  4. dd113
    dd113
    2,923
    1
    Jun 13, 2003
    What portion of the test did you fail and how bad? Exhaust is really not all that complicated nor expensive. It gets expensive as people just start replacing parts at random hoping to fix it. My first guess is the cat or the o2 sensors. They usually are the issue. Pin Head that posts here and on CCOT, POR seems to have a real handle on how to diagnose.
  5. Pskhaat
    Pskhaat
    2,629
    1
    Aug 19, 2003
    Morrison Formation
    Replace your plugs, cap & rotor, and wires if need be. You can even try to lean the carb slightly for the test. Change your oil to a 5-30 or lighter (depends on how good your rings are) for the test. Replace the PCV valve/air filter. Ensure your engine is at good operating temperature. Now what are the HC values of the emissions test? With this information you can then adjust some timing and the fuel used for the test accordingly, the State should allow another test in close timeframe for free.
  6. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    Get the emissions manual reprint from SOR and go from there. It will tell you how to troubleshoot the various emissions spaghetti and set up your timing and carb.
  7. Pin_Head
    Pin_Head
    13,731
    1,297
    Feb 6, 2002
    OC, CA
    If you bought this 60 in CA, then you are in luck, bucause it is HIS problem to make it pass smog, not yours. He is legally obligated to either have it checked before he sells it or make it pass after he sold it. You can either have him fix it until it passes or refund your money; your choice.
    Check the bureau of auto repair web site for the law on this.
  8. fj40crusher
    fj40crusher
    463
    4
    Nov 7, 2002
    Pacific NorthWest
    [quote author=Mike S link=board=1;threadid=5395;start=msg42405#msg42405 date=1063861010]
    Suggestions?
    Mike S
    [/quote]
    MOVE out of Communistfornia
