Fluid heat riser picture??
Discussion in '40- & 55-Series Tech' started by Bennett, Oct 10, 2004.
  1. Bennett
    Bennett
    627
    5
    Feb 1, 2002
    Utah
    Wanting to install a fluid heat riser on a 76' 2F with headers...wondered if anyone could take a minute to post a picture or explain where you tie into the heater line.
    I don't want to route a bunch of hoses all over teh place.
    thanks
    Bennett
  2. brian
    brian SILVER Star
    7,340
    769
    Feb 7, 2003
    lebanon,pa
    TT had a write on this about 1-1.5 yrs ago, bunch of pics and a flat plan for an adpter plate. i was thinking about going this route as well.
  3. Bennett
    Bennett
    627
    5
    Feb 1, 2002
    Utah
    What month TT..cause I have them and do not remember seeing it.
    thanks though
  4. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    I did this last winter when I installed a header on my '74 F motor. Used 1/2" aluminum plate cut to the profile of the bottom of the intake, made a gasket, but you could probably use silicone...I did both. Piped from the head to the heat riser then on to the heater. Tapped the plate for 1/2" FPT and screwed a couple of 90* that were barb fittings on one end and 1/2" FPT on the other.
    I tried to attach a pic...let's see how it goes.
    GL
    Ed
    BTW that is a 2F intake, so same design as yours would be. What you see in the picture is "street" elbos, male on one end and female on the other. What I ended up using was what I described in the post...one piece brass with 1/2" FPT on one end and barb fitting on the other, saved me some room and gave me a better approach for the hoses.
  5. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Nice lookin' headers, Ed.
    That's how I ran my fluid heatriser, too.
  6. Bennett
    Bennett
    627
    5
    Feb 1, 2002
    Utah
    I take it these heat risers make a heck of a difference??
  7. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Depends on where you live. If it gets below 30 degrees often, you'll notice it.
  8. Landpimp
    Landpimp GOLD Star
    14,679
    869
    Mar 14, 2003
    PNW
    Ed, what PS box is that?
  9. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    The PS box is out of an '84 minitruck, I got it from Woody. The fluid heat riser works well, but not as good as a set of mated manifolds and hot exhaust gasses. I also run a 2F aircleaner which has the flapper that can choose between heated intake air and cold air. I fashioned a warm air intake that hoseclamps to my header. I think that helps, too
  10. Doug_S
    Doug_S
    880
    Jul 19, 2004
    Olympia, WA
    John, you have a good eye. You're definitely not one to miss something. After you pointed it out I scoped it out.
