Sorry about misspeling your name.
So whats next ?
Did you ever look at how much those arms bind on the brackets?
For mathematical theory: for every inch you go below or above 3" lift.......theres a 25% negative return on the opposite side of the "onroad/ offroad" spectrum. ie. 4" lift nets you 25% less onroad handling/ stability. 5" - 50% worse onroad 6" - check seatbelts/ rollovers imminent.
delancey
trying to make his buggy into an 80.
We've seen how that turned out with the uber built, Baja, mid-engine rig.
Still don't know what that dood was thinking, but wish he'd take on a new project....
The SEs or OEs?
Really doesn't matter, because they NEED to bind to force the rear to comply, otherwise the rear remains rigid.
Within the confines of the OE links, there's no way to better balance traction at the four corners than what Mr. T did.
Looking at the unequal weight bias from front to rear axles, when the front binds, say with one wheel off the ground, it acts like a lever, shifts the weight to the other three tires by forcing the rear to comply increasing traction on the rear, and it's better to push than to pull.
Without forcing compliancy to the corners that have traction, opening up the front nets corners that, while the tire may be on the ground, there's not enough force on the tire for traction, but BECAUSE it's on the ground screws with forces that are imparted on the other tires, which now have less of an ability to maintain traction.
Not enough room for a coil capable of maintaining a reasonable ride height, to be able to push the tire down to offset this (what a dual rate should do, not just keep it in the bucket) effect.
On top of that, think it's better that the 80 driver maintain a feel of level that relates to the field of vision, because it's a fat pig.
Better the driver sees and feels all based on the front ends plane...if that makes sense.
Traction/stability > flexibility.
Think the best way to achieve this is gain all ground clearance with tires, smoothen out the belly as much as possible.
If the tires rub the frame rails or coils, widen axles.
If the ass still drags, cut it off.
Dunno.
Unparalleled 80 build.....if a resemblance to an 80 constitutes it being an 80. Well thought out and calculated design, construction was intense, to a degree that I believe you could roll at 100mph, flip it over and continue about the day, no problem.
But, in the back of my mind from first sight, brought about many "WTF was this guy thinking?" choosing an 80 to model after.
Think he woke up....
Edited: Side note:
@scottryana,
Have you seen the linked/cantilevered Pig build in the 'Sty?
@scottryana
Skip to about the middle.
Resto-mod on my 55 has begun
@richardlillard1
They are beef tastic compared to the OE's, eh?
Surely wasn't a forethought, but often wondered if the weight was figures to force compliancy from the front.....or even an anti-roll measure, since a lot of additional unsprung mass, down low.
Of course, that wondering ceased when proving the latter theory to be incorrect.
