Today - I pulled the transfer case off the 2F ( manual linkage ) and the 3B ( 62 style transfer case - although pulled out of a 61 )
There are some unique differences..
Larger issues.. ( many stated above )
- The lengths of the shafts are definitely different.. the 62 shaft which was made for the vacuum shift is almost an inch shorter- and it is indexed on the backside to maximize clearance between the vac shifter and the driveshaft behind it.
- The rod that the shifter shafts ride on is longer.
- The High Low lever in the 60's is pointed in the direction of travel in the vehicle in neutral.. and indexes right and left to change gears.. the 62's lever points towards the drivers ( US system ) side .. 90 degrees different- forward and back to actuate.
- The manual shaft has very significant detents in it for the ball/springto hold in gear. When I was reading.. I definitly had a different idea ( in my head ) about these denents than what was actually on the shaft.. I will attach a photo below so those off you who haven't seen one can visualize it better..
Smaller differences-
- The bolts that hold the transfer case to the gearbox have a 17mm as opposed to a 19mm head. Who knows.. Probably no big deal .. The lengths were identical.
I didn't have a rebuild kit.. I carefully saved and cleaned the gaskets - picked between the best ones.. and reinstalled them.. I couldn't ( in my cases ) find any noticeable differences in the principal gears or bearings.. ( Other than the actuating system / rod which we talked about earlier )
It took me 5 hours to pull both of them.. lay them out nicely.. clean them.. pick between the two to find the better bearings.. ( one was KOYO one was NACHI .. never use nachi if you can help it .. they seem to be a lower quality bearing ) and reassemble them both onto their respective engines.. The better ones stayed with the 3B.. I will sell the rest as parts.. 2F H55F Trasnfercase-
Photos below and in the previous posts..
1. Jammer and me.. pulling the beast- I had to use a come-along to hold the tail of the transfercase to adjust the angle.. We wouldn't have gotten it out without it..
2. Transfercase out in order of assembly.. note bearing puller.. very tight tolerances to pull the main shaft bearing.. this puller is key.. gentle and effective -
3. Face off.. back plate still in place -
