Will any year stock linkage work or just the later '85 and on?You take off the vac shift assembly and there will be a hole where the 2wd-4wd drive shaft comes out of. You slip the seal over the shaft and seat it in the "hole". Then you slip the booty over the shaft and pull it around the first seal just like on the 85 cases. You then can bolt up the stock linkage from an fj60 t-case.
