So I recently had a 1hdt swapped into my fj62. it has a new thermostat and the heater lines are run as close to the original set up as the new engine allows. the heaters both worked well prior to the swap. now the rear one works fine but the front won't heat up if I have the fresh air on. it used to heat hot in this configuration and would help keep my windows clear. now if I put it on recirculate I can get it to blow close to hot but the windows frost up that way. I figure my heater core is fine as it heats the front when on recirculate just not with fresh air!! any suggestions as to where the problem might lie. it's my daily driver so I dont want to pull the heater and dash all apart without having something to look for. can't find any threads with this exact same problem. engine will heat well above 1/2 up the gauge with cardboard up front and it'll still blow cold with fresh air on.
