Fj60 vacuum woes
Discussion in '60-Series Wagons' started by 83 chif, Oct 28, 2007.
  1. 83 chif
    83 chif
    352
    Sep 11, 2007
    New Jersey
    Hey everybody....I'm trying to clean up my boss's 85' FJ60 with the 2F motor in it. There is a vacuum leak somewhere so we did a new carb and new gaskets and new intake and exhaust manifold gaskets. we also want to clean up there emissions vacuum lines. Which of that can we pull off and still have the vehicle run? Do we need to just leave the vacuum advance or is there more to it than that? Any info is really appreciated. Thank you in advance!!
    - doug
  2. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,097
    204
    Mar 31, 2006
    Central California
    Buy a FSM.
    It will make your life a whole lot easier.
  3. CREWZER
    CREWZER
    139
    Sep 30, 2007
    X2 Da Animal That Is The Only Way To Do It Right.
  4. 83 chif
    83 chif
    352
    Sep 11, 2007
    New Jersey
    FSM?
    is that a tech manual? If it is, he has one already. It help in identifying the EGR and all that sort of stuff, but it didn't tell us how to properly rip everything out and still have the motor run well. thanks though...
  5. PAFJ
    PAFJ
    1,609
    Jul 27, 2005
    Mobile, AL
    You're not going to find this in any manual. The manual will give you a better understanding of the different emissions systems for maintenance and/or troubleshooting. Where are you located? Are you required smog tests? If not, look here:
    http://www.ih8mud.com/tech/smog/72706FJ60desmog.jpg
    Compare this image to the one in the FSM and it should get you started off on the right foot.
    HTH-
  6. D'Animal
    21,097
    204
    Mar 31, 2006
    Central California
    It is a Factory Service Manual.
    It is much easier to fix the smog system then rip them out. It is intimidating to look at but with a FSM it's not that bad.
  7. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    This is the diagram that is often very hard to read on the passenger side fender well. I have found it helpful.
    [​IMG]
  8. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    You may also consider replacing all the vacuum line. It's actually almost fun.
  9. D'Animal
    21,097
    204
    Mar 31, 2006
    Central California
    My 84 FJ 60 and the 86 FJ 60 has a decal but it does not look like that. I wish it did.
    That would be neat to print and laminate and keep in the glove box.
  10. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    Yeah it actually shows some hoses that the factory emissions manual does not.....
  11. 2mbb
    2mbb SILVER Star
    4,609
    47
    Sep 1, 2003
    WC, CA
  12. D'Animal
    21,097
    204
    Mar 31, 2006
    Central California
  13. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    Yes that's good. I want more!!! (said like a little kid banging his spoon on the table)
  14. 2mbb
    2mbb SILVER Star
    4,609
    47
    Sep 1, 2003
    WC, CA
    That top one is from the parts microfiche...
