fj60 overheating
Discussion in '40- & 55-Series Tech' started by Workingj, May 8, 2003.
  1. Workingj
    Workingj
    3
    May 8, 2003
    Please help a 60 owner as he attempts to become more mechanically self sufficient......My 60 overheated badly, went into the red for 30 seconds or so before I could pull over. Steamed a little after I stopped and vented coolant. Do I worry about engine damage? Never had overheating problems before. Radiator is less than 1 year old. Belts/Hoses are good. How can I tell if the probem is the thermostat, waterpump or something else?
  2. bernefj60
    bernefj60
    169
    Dec 18, 2002
    wait for it to cool down, then refill the radiator with water. Check for leaks.
    If you've blow a hose, it'll be obvious. When mine overheated, it was becasue the tiny hose that you don't know about yet that sits behind your water pump burst.
    Check your heater hoses, and your oil cooler (boxy thing on passenger side of block).
    if it's your water pump, you'll notice leakage from the lower weep hole.
    Thermostat - well, just replace that anyway.
    Do a compression test to see if you've blown the ehad gasket. Usually, you'll be able to tell from the billowy white smoke pouring from your tail pipe.
    good luck
    Rob
  3. preacherman
    preacherman
    234
    Oct 1, 2002
    Midland Texas
    I spent 4 weeks one time trying to find out why my j**p was overheating. I replaced everything in the cooling system only to find out it was my radiator cap which only cost $2.99. &nbsp:Dohhh!
  4. woody
    woody Internet Fireman Staff Member
    10,331
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    check the leak issue, then change the cheap stuff....
    radiator cap and thermostat.
    Fill and test from there, and let us know what happened.
    "instantaneous" overheats are usually a locked thermostat, busted hose, or a snapped rad cap. "easy" stuff...
    White smoke constantly while running = head gasket, milky white oil (pull the dipstick) can also be that.
  5. RangerDave
    RangerDave
    16
    Apr 15, 2003
    Go with the compression test. Any local mechanic should be able to do it for a minimal fee, if any fee at all. They can check the radiator cap too.
    I wouldn't worry too much about the overheating incident. On my old FJ40, I overheated one winter night on the NJ Turnpike and didn't notice it for several miles. The shaft on the water pump sheared off! Replaced the pump & radiator (when the shaft broke, it drove the fan right into the radiator) and all was well.
    BTW, I just replaced the radiator on my FJ62. Compression test showed a big leak around the bottom seal. Found a good deal on a radiator in Denver. They'll ship too.
    Good luck.
  6. Workingj
    Workingj
    3
    May 8, 2003
    Thanks for the help, I replaced the thermostat and it runs great. Easy job, but it was my first so I have a smile on my face!
