FJ60 e-brake problems
Discussion in '40- & 55-Series Tech' started by Jman, May 7, 2003.
  1. Jman
    Jman
    1,548
    172
    Feb 20, 2003
    If ya don't know, I ain't tellin'
    The e-brake assembly on my left rear wheel froze up a few months ago, so I took it apart and lubed everything, and it worked like a charm, until now.
    Again, it's just not releasing--when I remove the e-brake, the cable goes slack and I have to get out and move the lever by hand to avoid the drum from dragging while I drive.
    If I soak it with WD40 or Liquid Wrench, it goes away for a while, but then comes back. I can keep lubricating it every weekend until I finally get tired of it, but I was wondering if anyone has a solution. (Yeah, I know, new e-brake assemblies are $$$, just order one, yadda yadda.)
    Thanks.
  2. Lost_crusiers
    Lost_crusiers
    46
    Oct 15, 2002
    Hey I had the same reoccuring problem. I took out the lever, sanded it smooth, painted it then used anti-seize goo on the pivot and reasembled the brakes. That was two years age and all is still well. JL :D
