fj60 Carb adjust screws, what do they do?
Discussion in '60-Series Wagons' started by alvin9, Aug 2, 2008.
  1. alvin9
    alvin9
    236
    Jul 25, 2008
    Pasadena CA, SoCal.
    There are four of them. I have till Wed. If cant do it i will bring it to MArk in Burbank.
  2. Marc311
    Marc311
    947
    2
    Aug 7, 2006
    Northern Virginia
    Idle
    Fast Idle
    Idle mixture
    AC Idle up (I believe).
    Not sure I would attempt anything until you grab (or download) the FSM.
  3. 2mbb
    2mbb SILVER Star
    4,611
    52
    Sep 1, 2003
    WC, CA
    The screw on the right side of the carb (next to the valve cover) is the idle mixture screw. The one on the front of the carb adjusts the ac idle up. The two on the back of the carb are for idle speed and fast idle speed.
    The procedure for setting the idle speed and idle mixture is described in the attachment. I usually start with the idle mixture screw turned out (counter clockwise) 1 1/2 turns from it's seated position (turned all the way in). I turn the mixture screw in 1/4 turn increments (starting with counter clockwise), and wait for the rpms to stabilize, and conintue this in one direction until the rpm's maximize. I use a handheld tachometer to measure the rpm's. If I go a 1/4 turn too far (rpm's start to decrease), it's easy to find the maximum by turning the screw back the 1/4 turn. Once I'm close to the maximum I might do 1/8 turns (e.g. half as far as the 1/4 turn).
    You set the fast idle screw to get the desired idle speed when the choke is pulled out.
    If you set the AC idle up too high (screw it in too far) the idle will become unstable the AC is turned on. I have mine adjusted so the idle speed increase from 650 to about 1000 when the AC compressor engages.
  4. cbmontgo
    cbmontgo SILVER Star
    3,120
    44
    Feb 28, 2004
    Texas
    Not to hijack, but which screw would adjust the carb for altitude?
  5. Cruiserdrew
    Cruiserdrew SILVER Star
    13,253
    1,061
    Mar 15, 2003
    Sacramento, CA
    Does not exist. The 60 has a HAC built in that I think advances the timing a bit. I've never been convinced it does much.
    The way I think about the Aisin carb is that it isn't really adjustable, except for idle mixture. The main and secondary are only adjustable by disassembling the carb, and swapping out the jets. The other screws are just set screws that adjust how far the throttle opens under various conditions, like when the choke it pulled or the ac comes on. They don't adjust fuel mixture at all.
  6. cbmontgo
    3,120
    44
    Feb 28, 2004
    Texas
    That is what I thought too, but after I moved to Colorado, people have told me that I need to tune my carb for the altitude. It does fine up here, but I was wheelin' at 12,000' altitude a few weeks back and my engine died. Others with the Aisin who are from Colorado can go above that altitude. I am not sure what the difference is, but theirs somehow can make it higher than I can go.
  7. 2mbb
    2mbb SILVER Star
    4,611
    52
    Sep 1, 2003
    WC, CA
    The HAC does advance the timing, but it also leans out the primary hi/lo and secondary hi speed circuits. Maybe your HAC isn't working properly?
  8. hank14
    hank14
    2,370
    33
    Nov 26, 2004
    Texas
    ...Or until 2mbb posts up another excellent scan or download of the FSM. Thanks for always being there to help! :cheers:
  9. NocalFJ60
    NocalFJ60
    3,549
    Media:
    6
    2
    Aug 2, 2004
    San Francisco Bay Area
    Why do you think you need to adjust it? Failing smog?
    If it hasn't been rebuilt ever, then take it to Mark and start there. He rebuilt mine and would recommend him.
  10. JLH911
    JLH911
    2,399
    4
    Sep 2, 2007
    So. Cal
    X2 on having Mark rebuild it...you won't regret it.
  11. fliphkd778
    fliphkd778
    990
    Mar 10, 2007
    That's scary, "lean drop"?
    Does this explain the method, or the result? I don't want leaned out cylinders...
  12. NocalFJ60
    NocalFJ60
    3,549
    Media:
    6
    2
    Aug 2, 2004
    I think more the method. It is only adjusting things for idle.
  13. cbmontgo
    3,120
    44
    Feb 28, 2004
    Texas
    Yes, I am thinking that may be the problem. I am going to buy a new HAC.
    I rebuilt the carb will all Toyota parts 2 years ago, and it runs perfectly. I think the HAC or something thereabouts is the problem at high altitude.
  14. ModisetteJ
    ModisetteJ
    116
    10
    Apr 25, 2014
    Tyler, Texas
    Reviving this thread for a second... I live in East Texas Where the altitude is ~500 ft. I bought my cruiser in Denver where the altitude is 10x that. I've been driving my cruiser around for about a month hoping I would notice a change, but I fee like my carburetor is running way too rich. How would I adjust that? Is there a way to adjust it without pulling it apart?
  15. Output Shaft
    Output Shaft aka, OS SILVER Star
    3,296
    Media:
    15
    1,239
    Mar 31, 2014
    The Golden State (at least the sky is anyway)
    Threads never die.. they just sleep...
    Check the functionality of the High Altitude Compensation (HAC) System. It is supposed to be automatic and adjust the fuel/air mixture and spark advance at around 4000 ft. (depending on which way you are traveling). Sometimes the valve fails.
    The procedure how to do that is in the FSM. It's easy.
    It's a good first step to rule out.
    An engine at altitude requires a leaner mixture than at sea level.
    It is possible the the HAC valve got stuck in the 'High Altitude" position since it was living at high altitude for so many years. But a HAC valve stuck in the high altitude position would cause the engine to run leaner at sea level (500 ft), not richer. See above.
    LINK to FSM
