FJ60 Antenna
Discussion in '60-Series Wagons' started by JLH911, Nov 8, 2007.
  1. JLH911
    JLH911
    2,441
    11
    Sep 2, 2007
    So. Cal
    Can someone take a picture(and post it here)of the Antenna on a FJ60 down as far as it will go?
    I have a Cover for the FJ60, but don't want to cut a hole in it if the antenna goes down pretty flush with the body.
    Thanks!
  2. Matt60
    Matt60 KiSS of Death
    662
    Media:
    22
    Aug 24, 2005
    i'm sure you know this but the antenna boot sits on top of the fender and the top part of the antenna ball sits on that so its about 3/4 of an inch above the fender. the only reason speak is b/c i had my fender off 2 times tonight....
  3. Matt60
    662
    Media:
    22
    Aug 24, 2005
    found one shot
  4. JLH911
    JLH911
    2,441
    11
    Sep 2, 2007
    So. Cal
    Okay, thanks, but what's the farthest down it will go?
    I imagine it should go down to almost flush with the fender where only a small part of it will protrude from the fender.
  5. JLH911
    JLH911
    2,441
    11
    Sep 2, 2007
    So. Cal
    Okay, I got you...I guess I'll have to lube it up some more and get it to go down carefully.
  6. Matt60
    662
    Media:
    22
    Aug 24, 2005
    the ball sits on that chrome ring. the whole thing comes out easy... don't know why its up in that pic i never have it up?
  7. 2mbb
    2mbb SILVER Star
    4,614
    59
    Sep 1, 2003
    WC, CA
    If you can get it all the way down you shouldn't have to cut a hole in your cover. If you convert to the FJ62 power antenna, then you can raise and lower it from inside.
  8. Rob Faucett
    Rob Faucett SILVER Star
    385
    18
    Apr 19, 2006
    Seattle, WA
    Convert to the FJ62 power antenna
    How many people have done this? Sounds like a good idea.
  9. 2mbb
    2mbb SILVER Star
    4,614
    59
    Sep 1, 2003
    WC, CA
    I've done it. The FJ60 had an auto antenna option, but the motor/antenna has been superceded by the FJ62 part number. You will need the FJ60 specific up/down switch if you want it in the OEM location. At least on my 1985, the wiring harness was already there. Purchasing all this stuff new, though, is not an inexpensive endeavor. You might be able to source the FJ62 antenna used. Finding a used FJ60 switch will probably be more difficult.
  10. Rob Faucett
    385
    18
    Apr 19, 2006
    Seattle, WA
    Holy :censor:! SOR shows $188! Uuuuh, thats like 8 broken manuals:rolleyes:. Think I'll wait.
    Thanks
    Rob
  11. JLH911
    JLH911
    2,441
    11
    Sep 2, 2007
    So. Cal
    Right, that's why I want to get my Antenna all the way down, it's just giving me trouble.
    I'm gonna spray some PB blaster on it and let it soak in because right now it only goes halfway down.
    Thanks
  12. cruzerfetish
    cruzerfetish
    328
    Nov 11, 2004
    Portland OR
    the one that came on mine is a one piece that scres onto the base. Thought it was stock, so i don't think it goes down. If you have the same one, oyu could unscrew it when you put the cover on, and no need for a hole.
  13. jvazquez53
    jvazquez53
    3,103
    Media:
    13
    139
    May 6, 2007
    San Juan Puerto Rico
    I have one of those rubber antennas that work great, basically is indestructible.:beer:
