Fj40 V8 radiator?
Discussion in '40- & 55-Series Tech' started by godzilla, Jul 9, 2003.
  1. godzilla
    godzilla
    254
    Apr 20, 2003
    I recently went to my local radiator shop and they told me that they couldn't put anymore cores in the radiator I have(the stock one). What radiator setup do you guys use? I saw that downey has one, has anyone used this radiator? I was told that the motor will never run cool enough with the stock radiator is this true? I just want to get all the facts, I'm in the process of swaping the motor in right now. Any input would be greatly appreciated. Thanks
  2. woody
    woody Internet Fireman Staff Member
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    how warmed is your 350?
    My local shop squeezed 5 rows of fins into the stocker...works great. I run a 16" pusher for hot days and a normal clutch fan with no shroud. 350 carbie sat at 185-200, the TBI is always at 205 or so (where it should be)
    A shroud does wonders. A FlowKooler water pump is a good upgrade, from Summit. Try those before dumping $$ into the radiator.
  3. nspctr1
    nspctr1
    2,208
    2
    Jan 5, 2003
    San Antonio TX
    Although mine is not running yet, my radiator guy said you can add a 4th row and some guys might try to squeeze in a 5th but, a shroud works well to direct the air flow and a good electric fan. No need to run out and buy a 400 dollar radiator.
  4. Corbet
    Corbet Speski OffRoad LTD. Supporting Vendor
    3,727
    615
    Oct 22, 2002
    Durango, Colorado
    I had problems with overheating until I installed a high flow pump and thermostate. No shroud, 4 rows, clutch fan, Utah heat and no problems now. Highway or on the rocks.
  5. godzilla
    godzilla
    254
    Apr 20, 2003
    I ordered a high volume water pump and thermo from jegs, I'll let you know what the outcome is as soon as I get it back on the the road.
  6. lndcrzr71
    lndcrzr71
    34
    Apr 20, 2003
    i have a worked 350 in mine,i dont have any problems.Went wheeling at paragon on fri the 11th no probs.Drove it to bloomsberg sat no probs.my rad is out of a montycarlo and i'm running a 7 blade flexy.stays about 190-200.
  7. milesstarkey
    milesstarkey
    353
    Oct 15, 2002
    how can you tell if your water pump is working at its best ?
