FJ40 speed sender for vdo
Discussion in '40- & 55-Series Tech' started by Dunkane, Feb 18, 2008.
  1. Dunkane
    Dunkane
    448
    Media:
    4
    30
    Mar 3, 2004
    France
    hi !
    is someone have an idea on how to have pulses for a vdo vision speedometer gauge from a FJ40 transfer case ?
    vdo have only cable sender for GM , but not TOYOTA...:(
    there is also inductive vdo sender ref 340020 or 340021...but don't know where i could put this.
    thanks
  2. FJ40-GARAGE
    FJ40-GARAGE I`ll be back.... SILVER Star
    760
    Media:
    32
    207
    Dec 23, 2003
    Dorfweil / Germany
    Wait 8 hours and i will post some pictures and part numbers for you.:popcorn:
  3. FJ40-GARAGE
    760
    Media:
    32
    207
    Dec 23, 2003
    Dorfweil / Germany
    Here we go.
    I use a VDO Adapter Kit X39.397/106/130 that will be mounted in your speedometer wire.
    [​IMG]
    Its old school and works perfect under any given conditions.
    The adapter i use seems to be off the market nowadays but there are newer ones that will do the same.
    VDO X39-397-106-191
    [​IMG]
    Is there a way to adjust the speedometer you use......in my case i used a VDO Mini Cockpit, this unit is adjustable.
    [​IMG]
    Need more input.......... :idea:
  4. cronic
    cronic
    211
    3
    Aug 8, 2007
    N.C.
    You need to contact Roger at Speedometer service company. This is who I sourced my speed sensor and cable from for my VDO vision series speedometer in July of last year. He is very helpful and the speed sensor and cable worked perfect for the VDO.
    Speedometer Service of Milw providing speedometer solutions
  5. Dunkane
    Dunkane
    448
    Media:
    4
    30
    Mar 3, 2004
    France
    VDO speedo gauge fj40 , sender ?
    hi !
    is someone know how to pick a signal for a VDO speedometer gauge
    with a toyota transfer case ?
    there is no vdo adapter for the TOYOTA, only for the GM transfer case...
    thank you
    sorry , not seen, there was an answer to my question :)
    http://forum.ih8mud.com/40-55-series-tech/205819-fj40-speed-sender-vdo.html
    you can delete this post...
  6. Dunkane
    Dunkane
    448
    Media:
    4
    30
    Mar 3, 2004
    France
    thanks, i contact Roger...
  7. Dunkane
    Dunkane
    448
    Media:
    4
    30
    Mar 3, 2004
    France
  8. Downey
    Downey SILVER Star
    2,888
    229
    Jun 5, 2007
    Brea, Calif.
    Stealth Conversions have VSS pulse senders to fit Toyota transfer-cases (22mm with Toyota drive tangs) in a 2 pulse DC, and a 4 pulse AC or DC. If your VDO gauge takes anything different than that (adjustable???), then you could use a signal interface from Dakota Digital to change the signal to what you need. These are all "off the shelf" items!!!
  9. pappy
    pappy photosynthesizing Moderator
    7,826
    Media:
    78
    188
    Oct 7, 2003
    Palm trees and cool streams
    I was going to x2 on Speedometer Service Company, but it looks like you are set. SSC rocks. Not only did they provide me with an electronic sender for my Autometer speedo, but they also made the 4-pulse VSS for my 3FE EFI.
